Today I updated oneapi to 2021.2.0 (l_BaseKit_p_2021.2.0.2883_offline.sh).
I have already installed oneapi 2021.1.0 (l_BaseKit_p_2021.1.0.2659_offline.sh). I think it's an updating operation but I found both versions of oneapi on my server.
Both are installed in default directory.
After updated, I can't find icc.
[root@6248r-node121 intel64]# find / -name icc
/opt/compiler/intel/oneapi/compiler/2021.1.1/linux/compiler/include/icc
/opt/compiler/intel/oneapi/compiler/2021.1.1/linux/bin/ia32/icc
/opt/compiler/intel/oneapi/compiler/2021.1.1/linux/bin/intel64/icc
/opt/compiler/intel/oneapi/compiler/2021.2.0/linux/compiler/include/icc
I generate modulefiles with modulefiles-setup.sh in directory /opt/compiler/intel/oneapi.
But when I use it, I get :
[root@6248r-node121 modulefiles]# module use /opt/compiler/intel/oneapi/modulefiles
[root@6248r-node121 modulefiles]# module load compiler/latest
Loading compiler version 2021.2.0
Loading tbb version 2021.2.0
Loading debugger version 10.1.1
Loading compiler-rt version 2021.2.0
Lmod has detected the following error: /opt/compiler/intel/oneapi/modulefiles/compiler/latest: (compiler/latest): invalid command name "is-avail"
While processing the following module(s):
Module fullname Module Filename
compiler/latest /opt/compiler/intel/oneapi/modulefiles/compiler/latest
[root@6248r-node121 modulefiles]# module load mpi/latest
Removing mpi version 2021.2.0
Loading mpi version 2021.2.0
I can't load compiler correctly.
I have 2 problems:
1. where is icc of oneapi 2021.2.0?
2. Why modulefile of compiler does not work?
Intel classic C/C++ compilers(ICC/ICPC) are a part of HPC Toolkit. Please find the download link for HPC Toolkit below
https://software.intel.com/content/www/us/en/develop/tools/oneapi/hpc-toolkit/download.html
If you are facing conflict with the older oneAPI version, kindly uninstall the older version and proceed with the installation of the latest version. To uninstall older version, refer to the link.
For module files kindly refer to the below link after uninstalling the older version and installing the newer version:
Let me know if you face any issues.
Thanks & Regards
Sk. Noorjahan.
Thanks for posting in Intel forums.
We will try from our side and let you know. Meanwhile check if the previous version(2021.1.1) of oneapi Basekit is uninstalled.
Janani Chandran
Should I first uninstalled oneapi of previous version before installing the newerversion ?
Thanks & Regards
Sk. Noorjahan.
Thanks for the accepting the solution. Intel will no longer monitor this thread. Further discussions on this thread will be considered community only.
Thanks & Regards
Noorjahan.
