Intel® C++ Compiler
Aggregate initialization bug with nested struct
User87135761
Hi, I think I came across a compiler bug.
The following example throws on intel c++ compiler 2017.4.210
This is using c++14, Windows 7, Visual studio 2017.
#include <vector>
#include <stdexcept>
struct A
    int a;
    int b;
    int c;
    int d;
struct B
    A a;
    std::vector<int> b;
int main() {
    B b{};
    if (b.a.a || b.a.b || b.a.c || b.a.d) throw std::runtime_error("Compiler bug?");
b is initialized using empty braces, so it should performe aggregate initialization. b.a should be zero-initialized, but it is left uninitialized.
GouthamK_Intel
Thanks for reporting this bug. Ideally, it should have set the struct variables to 0.
We will inform this to the concerned team, in order to get it fixed.
Goutham
Viet_H_Intel
I've reported this issue to our Developer.
Sawin__Matthew
I have encountered a similar bug in compiler version 19.1 on linux. Aggregate initialization just doesn't initialize in some cases.
aggregate.cpp:
#include <cstdio>
//no bug if this is constexpr
inline int zero() { return 0; }
struct sub
  int v1 = zero();
  int v2 = 42;
struct agg
  sub s[2];
int main()
  printf("%d\n", agg{ }.s[0].v2);
  return 0;
$ icc -v && icc -O0 aggregate.cpp && ./a.out
icc version 19.1.0.166 (gcc version 8.3.1 compatibility)
1230900048
$ gcc -v && gcc -O0 aggregate.cpp && ./a.out
gcc version 8.3.1 20190311 (Red Hat 8.3.1-3) (GCC)
42
This is a pretty serious bug given how common empty brace initialization is. Is there any ETA on when this might be fixed?
As a workaround, you can compile with -Wmissing-field-initializers but you might find a lot of empty braces to fill in.
Viet_H_Intel
We don't have any ETA to share as this moment.
Viet_H_Intel
This issue is fixed in oneAPI2021.2.
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
I am going to close this thread.
