I am working on a project which has its own memory allocator. As in it gets 400 MB from the system(via one malloc call) and then allocates memory from it. Its written in C (so no placement new operators). I can control the way memory is allocated, by that I mean I can align the memory given to different structures to a certain boundary, say 64. But, I cannot use _mm_malloc. I can use _assume_aligned.
So my question is how do I make the icc compiler see that I have aligned the memory and it should vectorize the for loops with alignment ON. Are there any intrinsic function which I can call to tell the compiler about the alignment of a pointer ? Is there some flag which I need to set to let the compiler see that the memory is aligned ? Or is there any other way to do so. Any pointers will be helpful.
EDIT: I should have already added that I have been using the vector reports and the vector reports show for some reason that the pointers are unaligned but the loop was vectorizied using unaligned memory access. I want to gain performance by using aligned memory access. I have used "pragma vector aligned" but it hasn't yeilded any performance improvement. I have to use around 12 vectors in the array. Also, I can align the memory to a boundary but I cannot guarantee that the lower bound of the loop is going to be %64 == 0.
Gaurav
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Gaurav,
If your code is aligned on certain boundary, and there is no dependency, then the compiler will automatically vectorize it.
You can turn on the optimization report (-qopt-report-phase=vec) to get more details of your loop (i.e. vectorized or not)
Viet
