Intel® C++ Compiler
7956 Discussions
Are /arch and /Qax mutually exclusive?
Guillaume_A_
I just read /Qax documentation  and I am a bit confused. I quote:
"This option tells the compiler to generate multiple, feature-specific auto-dispatch code paths for Intel® processors if there is a performance benefit. It also generates a baseline code path"
"The baseline code path is determined by the architecture specified by options -m or -x (Linux* and macOS*) or options /arch or /Qx (Windows*)"
"If you specify both the -ax and -march options (Linux and macOS*), or the /Qax and /arch options (Windows), the compiler will not generate Intel-specific instructions."
I do not get it. How to generate baseline and Intel-specific instructions if /arch and /Qax mutually exclusive?
Is that a typo? Do I misunderstand something here?
I also wonder what would be the baseline code path when using /Qax whitout /arch nor /Qx.
In attachment a table of what I understand from the documentation. Could you correct and complete it please?
Context: I would like my code to run as fast as possible on non-Intel processors (AVX2 compatible), Intel Broadwell and Skylake processors.
My config: Windows 10 64bit, Intel One API 2021.1.1, Intel compiler 19.2.
Guillaume A.
Viet_H_Intel
The documentation on these options are somewhat confusing. Let me try to address all your questions:
No, only /arch and /Qx are mutually exclusive. The last one on the command line will be used?
baseline code path:
Ex: if you compiled with /QaxCORE-AVX2, then your baseline code path supports SSE2 and the optimized code path is targeted for Intel's AVX2.
feature-specific auto-dispatch code paths:
If you run the binary built with /QaxCORE-AVX2 on a system which doesn't support AVX2 (Intel and non-Intel), the baseline will be chosen to execute. If you run on Intel's AVX2 support  system, then the optimized codepath for Intel's AVX2 will be chosen.
Intel-specific instructions:
EX: Both Intel and Non-Intel hardwares are supported AVX512, but there are some AVX512 instructions only support on IA. For example, AFAIK, AVX-512 Vector Byte Manipulation Instructions (VBMI) only supports on IA.
Intel feature-specific optimizations:
For example above Intel specific-instructions: if you compile with /QaxICELAKE. Compiler may generate code that optimizes for ICELAKE and uses Intel feature specific (VBMI) as example.
What would be the baseline code path when compiling with /Qax without /arch nor /Qx?
The baseline will be supported SSE2.
What will be generated if I compile with: /arch:AVX /Qax:CORE-AVX2
There would be 3 code paths, one is default to SSE2, one is optimized for AVX (supported both IA and non-IA) and one is for  AVX2.
icl.exe /Qm64 /arch:AVX /Qopt-report:5 /Qopt-report-format:vs /QaxCORE-AVX2,CORE-AVX512.
The optimization report shows that the compiler generates paths for AVX, AVX2 and AVX512.
Could you confirm please?
Yes, but the compiler wont generate Intel-specific instructions.
Keep in mind that even both IA and non-IA are supported AVX, AVX2 and AVX512, but at instruction levels, they are not the same.
Hope that helps.
RahulV_intel
No Intel-specific instructions will be generated when -march (Linux/Mac) or /arch (Windows) flags are enabled along with -ax or /Qax flag. This is because specifying -march disables -ax and specifying /arch disables /Qax.
I need to check internally whether it's possible. I will let you know once I have the info.
Rahul
RahulV_intel
Since -march flag disables -ax, it would not be possible to generate Intel specific instructions.
Rahul
Guillaume_A_
Thanks for your answer Rahul.
It appears that the /Qax documentation has been modified since my first post. Now I read:
If you specify both the /Qax and /arch options, the baseline code will execute on non-Intel processors compatible with the setting specified for the /arch option.
If you specify both the /Qax and /arch options, the compiler will not generate Intel-specific instructions. This is because specifying /arch disables /Qax.
But /arch documentation says:
That does not means exactly the same thing. Am I wrong?
I am using the both options /arch:AVX and /Qax:CORE-AVX2 to compile my code. I am pretty sure that my program uses AVX2 instructions at runtime if the processor is compatible. I will try to confirm it.
I am sorry but it is still unclear for me. What are the differences between:
What would be the baseline code path when compiling with /Qax whitout /arch nor /Qx?
What will be generated if I compile with: arch:AVX /Qax:CORE-AVX2
Guillaume A.
Guillaume_A_
I just tried to compile with both  /arch and /Qax, from my point of view /arch does not disable /Qax
Eg:
void vectorSqrtD(double* Z, const double* X, const int n)
 __pragma(ivdep)
 for (int i = 0; i < n; i++){
 Z[i] = sqrt(X[i]);
compile with:
Guillaume A.
RahulV_intel
Do you have any updates?
Let us know if I can close this thread.
Rahul
Viet_H_Intel
baseline code path:
Hope that helps.
Guillaume_A_
Hello Viet,
Thanks for these detailed explanations.
It is ok, you may close this thread.
Guillaume A.
Viet_H_Intel
We will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
