I just read /Qax documentation and I am a bit confused. I quote:
"This option tells the compiler to generate multiple, feature-specific auto-dispatch code paths for Intel® processors if there is a performance benefit. It also generates a baseline code path"
"The baseline code path is determined by the architecture specified by options -m or -x (Linux* and macOS*) or options /arch or /Qx (Windows*)"
"If you specify both the -ax and -march options (Linux and macOS*), or the /Qax and /arch options (Windows), the compiler will not generate Intel-specific instructions."
I do not get it. How to generate baseline and Intel-specific instructions if /arch and /Qax mutually exclusive?
Is that a typo? Do I misunderstand something here?
I also wonder what would be the baseline code path when using /Qax whitout /arch nor /Qx.
In attachment a table of what I understand from the documentation. Could you correct and complete it please?
Context: I would like my code to run as fast as possible on non-Intel processors (AVX2 compatible), Intel Broadwell and Skylake processors.
My config: Windows 10 64bit, Intel One API 2021.1.1, Intel compiler 19.2.
Guillaume A.
The documentation on these options are somewhat confusing. Let me try to address all your questions:
Are /arch and /Qax mutually exclusive?
No, only /arch and /Qx are mutually exclusive. The last one on the command line will be used?
baseline code path:
Ex: if you compiled with /QaxCORE-AVX2, then your baseline code path supports SSE2 and the optimized code path is targeted for Intel's AVX2.
feature-specific auto-dispatch code paths:
If you run the binary built with /QaxCORE-AVX2 on a system which doesn't support AVX2 (Intel and non-Intel), the baseline will be chosen to execute. If you run on Intel's AVX2 support system, then the optimized codepath for Intel's AVX2 will be chosen.
Intel-specific instructions:
EX: Both Intel and Non-Intel hardwares are supported AVX512, but there are some AVX512 instructions only support on IA. For example, AFAIK, AVX-512 Vector Byte Manipulation Instructions (VBMI) only supports on IA.
Intel feature-specific optimizations:
For example above Intel specific-instructions: if you compile with /QaxICELAKE. Compiler may generate code that optimizes for ICELAKE and uses Intel feature specific (VBMI) as example.
What would be the baseline code path when compiling with /Qax without /arch nor /Qx?
The baseline will be supported SSE2.
What will be generated if I compile with: /arch:AVX /Qax:CORE-AVX2
There would be 3 code paths, one is default to SSE2, one is optimized for AVX (supported both IA and non-IA) and one is for AVX2.
icl.exe /Qm64 /arch:AVX /Qopt-report:5 /Qopt-report-format:vs /QaxCORE-AVX2,CORE-AVX512.
The optimization report shows that the compiler generates paths for AVX, AVX2 and AVX512.
Could you confirm please?
Yes, but the compiler wont generate Intel-specific instructions.
Keep in mind that even both IA and non-IA are supported AVX, AVX2 and AVX512, but at instruction levels, they are not the same.
Hope that helps.
No Intel-specific instructions will be generated when -march (Linux/Mac) or /arch (Windows) flags are enabled along with -ax or /Qax flag. This is because specifying -march disables -ax and specifying /arch disables /Qax.
I need to check internally whether it's possible. I will let you know once I have the info.
Rahul
Since -march flag disables -ax, it would not be possible to generate Intel specific instructions.
Rahul
Thanks for your answer Rahul.
It appears that the /Qax documentation has been modified since my first post. Now I read:
If you specify both the /Qax and /arch options, the baseline code will execute on non-Intel processors compatible with the setting specified for the /arch option.
If you specify both the /Qax and /arch options, the compiler will not generate Intel-specific instructions. This is because specifying /arch disables /Qax.
But /arch documentation says:
That does not means exactly the same thing. Am I wrong?
I am using the both options /arch:AVX and /Qax:CORE-AVX2 to compile my code. I am pretty sure that my program uses AVX2 instructions at runtime if the processor is compatible. I will try to confirm it.
I am sorry but it is still unclear for me. What are the differences between:
- baseline code path
- feature-specific auto-dispatch code paths (/Qax documentation)
- Intel-specific instructions (/Qax documentation) (/arch documentation)
- Intel feature-specific optimizations (/Qx documentation)
What would be the baseline code path when compiling with /Qax whitout /arch nor /Qx?
What will be generated if I compile with: arch:AVX /Qax:CORE-AVX2
Guillaume A.
I just tried to compile with both /arch and /Qax, from my point of view /arch does not disable /Qax.
Eg:
void vectorSqrtD(double* Z, const double* X, const int n)
__pragma(ivdep)
for (int i = 0; i < n; i++){
Z[i] = sqrt(X[i]);
compile with:
Guillaume A.
Do you have any updates?
Let us know if I can close this thread.
Rahul
baseline code path:
Hope that helps.
Hello Viet,
Thanks for these detailed explanations.
It is ok, you may close this thread.
Guillaume A.
We will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
