Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
7749 Discussions
Are there any technical references/white papers describing the output in the vectoriser/optimiser/auto-parallel reports
dehvidc1
I'm using thevectoriser, optimiser and auto-parallel reports provided by ICC. Ideally, there would be technical references that detail the contents of the reports. Atechnical reference of this nature could also be cited. Are there any technical references/white papers describing the output in the vectoriser/optimiser/auto-parallel reports? I haven't been able to find any
David
Milind_Kulkarni__Int
New Contributor II
Did you go through Compiler User Guide/ Documentation found with the install, in Start>Program Files> Intel> Compiler Pro> Help > User and Reference guide.
I mean main_cls.chm file.. That lists much of the things you need .. you can go through Contents..
What I typically do to speed up the search , is go to Search Tab. > Type:-- -openmp-report, or -opt-report, or -vec-report , -par-report, and go to the searched contents..
dehvidc1
That's great. Thanks for that. I have ICC installed as part of Parallel Studio as against a standalone installation so I had to go through a slightly different route to find main_cls.chm. This has the info I need to get started with my writeup.
