Intel® C++ Compiler
Assembly Listings with -fcode-asm
mettex
I tried to create an assembly listing with code annotations. I tried to do it on a windows and a linux machine. From my compile runs i got several outputs:
Windows:
"icl /C /Fa test.cpp" => asm-file
"icl /C /Fa /FAc test.cpp" => cod-file
Linux:
"icc -S test.cpp" => s-file
"icc -S -fcode-asm test.cpp" => cod.file
asm-file and s-file have different formats. If I got this correct, s-file from Linux-Version is in Intel-format. The same is true for cod-file from Windows and cod-file from Linux. cod-file on Linux is in Intel-format.
And now to my question:
On the windows machine i see in the cod-file the machine code annotations. E.g:
.B1.1: ; Preds .B1.0
00000 8b 54 24 04 mov edx, DWORD PTR [4+esp] ;D:\\cotest\\test.cpp:12.7
00004 89 11 mov DWORD PTR [ecx], edx ;D:\\cotest\\test.cpp:12.28
On the linux machine i see no machine code annotations, only the filename is now provided. E.g:
..B1.1: # Preds ..B1.0
movl 4(%esp), %edx #test.cpp:12.7
movl 8(%esp), %eax #test.cpp:12.7
First Question: Am I doing something wrong or why are the machine code annotations missing on my linux-machine?
Second Question: Is there an icc-option like the gcc-option -masm=[intel|att]?
Thank you for your help.
Some more details:
* icc V 11.1 20100414.
* test.cpp:
class Test {
public:
Test(int i);
int testMethod(int a, int b);
private:
int m_int;
Test::Test(int i) : m_int(i) {}
int Test::testMethod(int a, int b) { return a + b + m_int;}
mecej4
Black Belt
"If I got this correct, s-file from Linux-Version is in Intel-format" -- No, .s files are in AT&T (adopted by GNU) format.
There is a utility for converting .o/.obj files, called objconv.
You can run the GNU assembler ('as' on Linux) with the -a option to produce a listing with code bytes. With compilers that allow you to pass options to the assembler, you can use something resembling -Wa,.
mecej4
Black Belt
mettex
Thank you, mecej4!
Your hints helped me solving my problem for now. I can do the job on linux by using some different tools during compilation.
Still I am confused about the output from icc on my linux machine with the "icc -S -fcode-asm ...". I expected another information than only giving me a filename in the comment. objconv (and also the windows Version icl) gives me what I expected but I prefer working with icc on linux.
Linux: "icc -S ..." gives me:
addl 8(%esp), %eax #10.49
addl 12(%esp), %eax #10.53
Linux: "icc -S -fcode-asm" gives me:
addl 8(%esp), %eax #test.cpp:10.49
addl 12(%esp), %eax #test.cpp:10.53
Windows: "icc -S -fcode-asm" gives me:
00002 03 44 24 04 add eax, DWORD PTR [4+esp] ;D:\cotest\test.cpp:15.49
00006 03 44 24 08 add eax, DWORD PTR [8+esp] ;D:\cotest\test.cpp:15.53
mecej4
Black Belt
Why does one have to go through an extra step to obtain a listing with code bytes included? Because many compilers directly produce an object file (in the proper format for the platform, such as ELF, COFF, OBJ, etc.) and do not use an assembly step at all.
With such compilers, if you ask for an assembly listing, they may have to perform additional steps to produce one for you, and the listing may not be exactly the same as what you obtain by running a disassembler (such as objdump -d ) on the .o file.
jimdempseyatthecove
Black Belt
The asm option is used to produce an assembly source file (one you can modify and then assemble using the dialect of the assembly source). Additional options are available to have the compiler perform the assembly and then emit an assembly listing file (with or without .c/.cpp source embedded as comments).
Note, other than for "no optimization" trying to follow embedded source comments is problematic as statements are rearranged, merged, unrolled, and/or eliminated.
Jim
Kittur_G_Intel
Jim has given you the correct response (thanks Jim). Yes, icc will produce the assembly file with -fcode-asm that will also contain source annotations to help understand the code in detail....
-regards,
Kittur
mettex
I think I understand things better now ...
Thanks for your help.
mettex
