I am trying to use ICL to generate assembly and then do some processing of assembly and finally generate the binary using the updated assembly. However, this workflow does not work because the assembly generated by ICL seems not acceptable by ML64.exe
Following is output of compiling a simple Hello World style program:
main() { printf ("test\n"); }
Commands and outputs below:
$ icl /S test.c
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.2.187 Build 20170213
Copyright (C) 1985-2017 Intel Corporation. All rights reserved.
test.c
$ icl test.asm
test.asm
Assembling: test.asm
test.asm(18) : error A2008:syntax error : .1
test.asm(27) : error A2008:syntax error : .5
test.asm(35) : error A2008:syntax error : .2
test.asm(42) : error A2008:syntax error : .3
test.asm(50) : error A2008:syntax error : .main
test.asm(57) : error A2008:syntax error : .main
test.asm(58) : error A2006:undefined symbol : .B1
test.asm(59) : error A2006:undefined symbol : .unwind
Would this be fixable?
david
Show the contents of test.asm around line 18.
Can you issue the masm command directly?
Jim Dempsey
I don't think this works with Microsoft either (you'd need to use the /Fa option since Microsoft doesn't support /S).
These options actually create a listing file that contains assembly - not a file that can be parsed by the assembler directly.
Thanks for the suggestion. I tried /Fa and it did not work nether (same errors).
15 PUBLIC main 16 ; --- main() 17 main PROC 18 .B1.1:: ; Preds .B1.0 19 ; Execution count [1.00e+000]
I think the problem is the dotted label. If I run ML64.exe directly, I got the same errors:
ml64 test.asm
Microsoft (R) Macro Assembler (x64) Version 12.00.31101.0
Copyright (C) Microsoft Corporation. All rights reserved.
Thanks for the help.
david
It appears to be the "." in .B1.1, .unwind.main.B1_B2 and elsewhere.
For Intel guru: Is there an option to "icl foo.asm" to compile/assemble the .asm with .'s in the symbol names?
Jim Dempsey
[ Example 1 ]
;;///////////////////////////////////////////////////////////////////////////// ;; Hello32.asm - 'Hello, World!' 32-bit Test Application ;; ;; Release ;; ml.exe Hello32.asm /link /subsystem:windows /defaultlib:kernel32.lib /defaultlib:user32.lib /entry:Start /release /out:Hello32.exe ;; Debug ;; ml.exe Hello32.asm /Zi /link /subsystem:windows /defaultlib:kernel32.lib /defaultlib:user32.lib /entry:Start /out:Hello32D.exe .586P .MODEL FLAT, STDCALL ;; include kernel32.inc ;; include user32.inc includelib kernel32.lib includelib user32.lib .DATA caption db '32-bit Platform', 0 msg db 'Hello, World!', 0 .STACK .CODE extern ExitProcess@4 : PROC extern MessageBoxA@16 : PROC public Start Start: push 0 ; uType = MB_OK push offset caption ; LPCSTR lpCaption push offset msg ; LPCSTR lpText push 0 ; hWnd = HWND_DESKTOP call MessageBoxA@16 push eax ; uExitCode = MessageBox( ... ) call ExitProcess@4 END
[ Example 2 ]
;;///////////////////////////////////////////////////////////////////////////// ;; Hello64.asm - 'Hello, World!' 64-bit Test Application ;; ;; Release ;; ml64.exe Hello64.asm /link /subsystem:windows /defaultlib:kernel32.lib /defaultlib:user32.lib /entry:Start /release /out:Hello64.exe ;; Debug ;; ml64.exe Hello64.asm /Zi /link /subsystem:windows /defaultlib:kernel32.lib /defaultlib:user32.lib /entry:Start /out:Hello64D.exe .DATA caption db '64-bit Platform', 0 msg db 'Hello, World!', 0 .CODE extrn MessageBoxA : PROC extrn ExitProcess : PROC public Start Start PROC sub rsp, 28h mov rcx, 0 ; hWnd = HWND_DESKTOP lea rdx, msg ; LPCSTR lpText lea r8, caption ; LPCSTR lpCaption mov r9d, 0 ; uType = MB_OK call MessageBoxA add rsp, 28h mov ecx, eax ; uExitCode = MessageBox( ... ) call ExitProcess Start ENDP END
[ Example 3 ]
;;///////////////////////////////////////////////////////////////////////////// ;; HelloWorld32.asm - 'Hello, World!' 32-bit Test Application ;; ;; Release ;; ml.exe HelloWorld32.asm /link /subsystem:console /defaultlib:kernel32.lib /entry:Start /release /out:HelloWorld32.exe ;; Debug ;; ml.exe HelloWorld32.asm /Zi /link /subsystem:console /defaultlib:kernel32.lib /entry:Start /out:HelloWorld32D.exe .586P .MODEL FLAT, STDCALL .DATA handle dword 0h msg db 'Hello, World!', 10, 0 written dword 0h .STACK .CODE extern GetStdHandle@4 : PROC extern WriteConsoleA@20 : PROC extern ExitProcess@4 : PROC public Start Start: push -11 call GetStdHandle@4 ;; handle = GetStdHandle( -11 ) mov handle, eax push 0 push offset written push 14 push offset msg push handle call WriteConsoleA@20 ;; WriteConsole( handle, &msg[0], 14, &written, 0 ) push 0 call ExitProcess@4 ;; ExitProcess( 0 ) END
[ Example 4 ]
;;///////////////////////////////////////////////////////////////////////////// ;; HelloWorld64.asm - 'Hello, World!' 64-bit Test Application ;; ;; Release ;; ml64.exe HelloWorld64.asm /link /subsystem:console /defaultlib:kernel32.lib /entry:Start /release /out:HelloWorld64.exe ;; Debug ;; ml64.exe HelloWorld64.asm /Zi /link /subsystem:console /defaultlib:kernel32.lib /entry:Start /out:HelloWorld64D.exe .DATA handle qword 0h msg db 'Hello, World!', 10, 0 written qword 0h .CODE extern ExitProcess : PROC extern GetStdHandle : PROC extern WriteConsoleA : PROC public Start Start PROC ;; int 3 sub rsp, 38h mov ecx, -11 call GetStdHandle ;; handle = GetStdHandle( -11 ) mov qword ptr handle, rax mov qword ptr [rsp+20h], 0 lea r9, qword ptr written mov r8d, 14 lea rdx, qword ptr msg mov rcx, qword ptr handle call WriteConsoleA ;; WriteConsole( handle, &msg[0], 14, &written, 0 ) ;; xor ecx, ecx mov ecx, 1 call ExitProcess ;; ExitProcess( <return code > ) Start ENDP END
[ Example 5 ]
;;///////////////////////////////////////////////////////////////////////////// ;; Powers32.asm ;; ;; Displays powers of 2 from 2^0 to 2^31, one per line, to standard output. ;; ml.exe Powers32.asm /c" ;; link.exe Powers32.obj libc.lib /version:6.1 ;; By default, the linker uses "/subsystem:console /entry:mainCRTStartup". ;; The function "mainCRTStartup" is inside libc.lib. It does some ;; initialization, calls a function "_main" (which will end up in powers.obj) ;; then does more work and finally calls ExitProcess. .586P .model flat extern _printf : near public _main .data format byte '%d', 10, 0 .code _main: push esi ; save registers push edi mov esi, 1 ; current value mov edi, 31 ; counter L1: push esi ; push value to print push offset format ; push address of format string call _printf add esp, 8 ; pop off parameters passed to printf add esi, esi ; double value dec edi ; keep counting jnz L1 pop edi pop esi ret end
[ Example 6 ]
;;///////////////////////////////////////////////////////////////////////////// ;; Powers64.asm ;; Displays powers of 2 from 2^0 to 2^31, one per line, to standard output. ;; ml64.exe Powers64.asm /c" ;; link.exe Powers64.obj libc.lib /version:6.1 ;; ml64.exe Powers64.asm /link C:\PlatformSDK\Lib\AMD64\libc.lib C:\PlatformSDK\Lib\AMD64\bufferoverflowu.lib /subsystem:console /defaultlib:kernel32.lib /entry:main ;; ml64.exe Powers64.asm /link C:\PlatformSDK\Lib\AMD64\libcmt.lib C:\PlatformSDK\Lib\AMD64\bufferoverflowu.lib /entry:main extern printf : proc public main .DATA format byte '%d', 10, 0 .CODE main PROC sub rsp, 28h push rsi ; callee-save registers push rdi mov esi, 1 ; current value mov edi, 31 ; counter L1: push rsi ; push value to print lea rax, byte ptr format push rax ; push address of format string call printf add esp, 8 ; pop off parameters passed to printf add esi, esi ; double value dec edi ; keep counting jnz L1 pop rdi pop rsi add rsp, 28h ret main ENDP end
Hi Sergey,
Thanks for the examples. Could you tell me the right ICL flags to generate assembly like you attached. I can see they don't have label prefixed with dots.
david
Sergey Kostrov wrote:
>>...Could you tell me the right ICL flags to generate assembly like you attached...
Sources for all these 6 examples are Not generated by Intel C++ compiler. I've implemented these small tests as a spin off of some task related to usage of MASM ( 32-bit and 64-bit ).
I see. Does it mean it is not possible to start from C/C++ source, compile to assembly, and then assemble to binary executable?
Thanks for the advice.
david
To summarize, I think I need the ICL flags to compile C/C++ source into assembly that is compilable by MASM.
david
>>...I think I need the ICL flags to compile C/C++ source into assembly...
Take a look at Output, Debug, PCH section of command line options.
There are several flags mentioned in "Output, Debug, PCH section": "/S", "/FAs", "/FAc", "/FA". I tried them all but none of them work.
/S, /FA, /FAs - assembly generated with bad labels like ".B1.1"
/FAc - no assembly generated.
Please let me know if I missed any flags there.
Thanks a lot.
david
I address my post to Intel C++ compiler team software engineers. Please take a look at the problem because it is Not possible to compile asm-files generated by Intel C++ compiler. I just did a quick verification and instead of '.' ( dots ) in labels:
... .B1.1:: ; Preds .B1.0 sub rsp, 40 ;4.1 mov ecx, 3 ;4.1 call __intel_new_proc_init ;4.1 ; LOE rbx rbp rsi rdi r12 r13 r14 r15 xmm6 xmm7 xmm8 xmm9 xmm10 xmm11 xmm12 xmm13 xmm14 xmm15 .B1.12:: ; Preds .B1.1 stmxcsr DWORD PTR [32+rsp] ;4.1 or DWORD PTR [32+rsp], 32832 ;4.1 ldmxcsr DWORD PTR [32+rsp] ;4.1 ...
underscore '_' needs to be used:
... .B1_1:: ; Preds .B1_0 sub rsp, 40 ;4.1 mov ecx, 3 ;4.1 call __intel_new_proc_init ;4.1 ; LOE rbx rbp rsi rdi r12 r13 r14 r15 xmm6 xmm7 xmm8 xmm9 xmm10 xmm11 xmm12 xmm13 xmm14 xmm15 .B1_12:: ; Preds .B1_1 stmxcsr DWORD PTR [32+rsp] ;4.1 or DWORD PTR [32+rsp], 32832 ;4.1 ldmxcsr DWORD PTR [32+rsp] ;4.1 ...
or something else that would allow to compile asm-file.
