Intel® C++ Compiler
Assembly output issue
jwitmann
I should have reported this long ago, but I did a script that was fixing my issue. To put it simply, the way the LABEL are encoded is wrong since v11.0, and MASM would not process and assemble the file because of it. It seems someone decided to replace the '$' in labels by '.', which in turn breaks everything.
Back when the compiler was still on v10.1 a typical asm output was like:
_BASE64_freeContext PROC NEAR
$B1$1: ; Preds $B1$0
mov eax, DWORD PTR _mp_decBase64 ;58.17
test eax, eax ;58.5
jne $B1$3 ; Prob 68% ;58.5
; LOE eax ebx ebp esi edi
$B1$2: ; Preds $B1$1
mov eax, -6001 ;59.9
ret ;59.9
$B1$3: ; Preds $B1$1
push eax ;58.17
call DWORD PTR __imp__free ;62.9
; LOE ebx ebp esi edi
$B1$8: ; Preds $B1$3
pop ecx ;62.9
$B1$4: ; Preds $B1$8
mov DWORD PTR _mp_decBase64, 0 ;63.9
xor eax, eax ;
$B1$5: ; Preds $B1$4
ret ;66.12
ALIGN 4
; LOE
From version 11.x the code output changed to:
.B4.1: ; Preds .B4.0
mov eax, DWORD PTR [_mp_decBase64.0] ;58.17
test eax, eax ;58.17
jne .B4.3 ; Prob 68% ;58.17
.B4.2: ; Preds .B4.1
ret ;59.9
.B4.3: ; Preds .B4.1
push eax ;58.17
call DWORD PTR [__imp__free] ;62.9
.B4.8: ; Preds .B4.3
pop ecx ;62.9
.B4.4: ; Preds .B4.8
mov DWORD PTR [_mp_decBase64.0], 0 ;63.9
xor eax, eax ;
.B4.5: ; Preds .B4.4
ret ;66.12
ALIGN 16
; LOE
This is not really hard to fix by a postprocessing tool, however It'd be better if the compiler was outputting directly the right syntax.
Jerome
