Intel® C++ Compiler
7877 Discussions
Assertion Bug with icc in 13.1 and 14.0
James_B_14
The following code breaks
typedef unsigned long uint64_t;
void*  test(uint64_t* stuff, uint64_t column_length, uint64_t start)
uint64_t (*source)[column_length] = (uint64_t (*)[column_length]) stuff + start;
return source;
I get the folowing error:
% icc test.c
test.c(4) (col. 67): internal error: assertion failed: dump_expr_il0: NULL expression (shared/cfe/edgglue/edg_expr.c, line 5371)
compilation aborted for test.c (code 4)
Thanks in advance to any help.
TimP
Black Belt
Can you accept uint64_t from stdint.h ?  Which OS?
QIAOMIN_Q_
Seems there has some problem in front-end's evaluation in this case.I have reproduced as you said and have entered this issue into our problem-tracking database.Thank you for submitting the issue.I'll let you know when I have an update from development team.
Thank you.
QIAOMINQ.
Intel Developer Support
Please participate in our redesigned community support web site:
Tools Knowledge Base:           http://software.intel.com/en-us/articles/tools
James_B_14
I am using RHEL 6.4.
QIAOMIN_Q_
Hello James,
This bug has been fixed in the latest compiler SP1 Update3 ,Version 14.0.3.174 Build 20140422 .Please have a check .
Thank you.
QIAOMINQ.
