I can't manage to compile the header only parallel hashmap library with the latest icc (19) on Windows 10
https://github.com/greg7mdp/parallel-hashmap
Just including the header ( <parallel_hashmap/phmap.h>), create a basic hashmap, and compiling with the suggested building options (c++ 11 support), and I get the following error:
#include <parallel_hashmap/phmap.h> int main() { phmap::flat_hash_map<unsigned int, unsigned int> sides_table; }
assertion failed at: "shared/cfe/edgcpfe/lower_init.c", line 7013
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\parallel_hashmap\phmap.h 1202
With the visual studio compiler, it works fine.
Thank you very much
What Visual Studio version are you using?
Using this: Intel® System Studio 2019 Update 3 Integration for Microsoft* Visual Studio* 2017, Version 19.0.6.15,
This program crashes the compiler:
#include <parallel_hashmap/phmap.h> int main() { // Create an unordered_map of three strings (that map to strings) phmap::flat_hash_map<int, int> email; return 0; }
1>------ Build started: Project: ex_basic, Configuration: Release x64 ------ 1>basic.cc 1>C:\greg\github\parallel-hashmap\parallel_hashmap/phmap.h(992): error : assertion failed at: "shared/cfe/edgcpfe/lower_init.c", line 7013 1> 1> raw_hash_set() noexcept( 1> ^ 1> 1>compilation aborted for C:\greg\github\parallel-hashmap\examples\basic.cc (code 4) 1>Done building project "ex_basic.vcxproj" -- FAILED.
However if you initialize the hash map it builds fine... Following program compiles:
#include <parallel_hashmap/phmap.h> int main() { // Create an unordered_map of three strings (that map to strings) phmap::flat_hash_map<int, int> email = { { 1, 1 } }; return 0; }
1>------ Build started: Project: ex_basic, Configuration: Release x64 ------ 1>basic.cc 1>ex_basic.vcxproj -> C:\greg\github\parallel-hashmap\build\Release\ex_basic.exe ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
Actually this simpler program crashes the compiler:
#include <parallel_hashmap/phmap.h> struct Empty {}; int main() { phmap::container_internal::CompressedTuple<Empty> x{{}}; return 0; }
I am the author of parallel_hashmap, so if you can suggest a way to avoid this issue by changing the code I'll be happy to incorporate it.
you can see which VS versions supports at https://software.intel.com/en-us/articles/intel-compilers-integration-support-for-microsoft-visual-studio-2017
