Hi all,
Using ICL 13 SP1 Update 5 and Visual Studio 2013 Update 4 I get the following error on multiple files:
C:\Program Files (x86)\Intel\Composer XE 2013 SP1\compiler\include\atomic(16): internal error: access violation #include_next <atomic> ^
I've attached the following things:
- Files this error occurs on
- Build log
- Preprocess of those files
There are many more files where the same issue occurs, but too many to include.
Any help would be greatly appreciated!
An update to this, modifying atomic to the following:
#ifndef __USE_INTEL_ATOMICS #if _MSC_VER > 0 && _MSC_VER <= 1800 #define __USE_INTEL_ATOMICS 1 #endif #if __GNUC__ > 0 && (__GNUC__ < 4 || __GNUC__ == 4 && __GNUC_MINOR__ < 5) #define __USE_INTEL_ATOMICS 1 #endif #if defined(__VXWORKS__) #define __USE_INTEL_ATOMICS 1 #endif #endif #if __USE_INTEL_ATOMICS #include <stdatomic.h> #else #include_next <atomic> #endif
Changes the issues to being the exact same issue as defined in this previous thread Intel C++ 2013 compatibility issue with VC++11 in <atomic>. The problem is the temporary solution provided there doesn't work, because the error changes from already declared in scope to undefined.
EDIT: Can also confirm this occurs on ICL 15 Update 2
I am not sure if this is an internal compiler error.
I can't reproduce any errors or warnings using your pre-processed files. What's your command line?
C:\ISN_Forums\U545082\Intel Debug>icl -c GenericModule.i plugin-container.i -Qstd=c++11 /TP
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.2.179 Build 20150121
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
GenericModule.i
plugin-container.i
Patrick
