The compiler is incorrectly sign-extending halfword operations at all optimization levels above O0. I hit this bug with XE 2013 edition, but I have confirmed the problem exists in the most recent 2016 edition as well. This is affecting a critical project, can you please investigate? A reduced test case is provided below.
Code:
#include <stdio.h>
typedef short size2s_t;
typedef int size4s_t;
typedef long long int size8s_t;
size8s_t vrmpyhacc(size8s_t Rxx, size8s_t Rss, size8s_t Rtt)
Rxx = Rxx +
(size2s_t)((Rss>>(0*16))&0xffff) * (size2s_t)((Rtt>>(0*16))&0xffff)
+ (size2s_t)((Rss>>(1*16))&0xffff) * (size2s_t)((Rtt>>(1*16))&0xffff)
+ (size2s_t)((Rss>>(2*16))&0xffff) * (size2s_t)((Rtt>>(2*16))&0xffff)
+ (size2s_t)((Rss>>(3*16))&0xffff) * (size2s_t)((Rtt>>(3*16))&0xffff);
return Rxx;
int main()
typedef union {
signed long long db;
signed short hw[4];
} newvar;
newvar Rxx, Rss, Rtt;
Rss.hw[0] = -5;
Rss.hw[1] = -10;
Rss.hw[2] = -1;
Rss.hw[3] = -9;
Rtt.hw[0] = -3;
Rtt.hw[1] = -8;
Rtt.hw[2] = -5;
Rtt.hw[3] = -1;
Rxx.db = 0;
printf("vrmpyhacc: 0x%llx\n", (long long unsigned int) vrmpyhacc(Rxx.db, Rss.db, Rtt.db));
return 0;
Build:
icl vector.c -O1
Run (observed output):
vrmpyhacc: 0xffffffffffde006d
Expected output:
vrmpyhacc: 0x6d
I tried with the latest 2016 version: Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.110 Build 20150815
It worked fine with with -O2 and -O3 (with VS2013) but yes it does fail with -O1 and is a bug.
Can you let me know the system details including VS version etc? Also, can you attach a pre-processed file generated with (/P) as well? Thanks
_Kittur
You could remove ambiguities in standards interpretation:
Rxx = Rxx + (( (Rss>>(0*16)) * (Rtt>>(0*16)) + (Rss>>(1*16)) * (Rtt>>(1*16)) + (Rss>>(2*16)) * (Rtt>>(2*16)) + (Rss>>(3*16)) * (Rtt>>(3*16)) ) & 0xFFFF);
Jim Dempsey
No, I really can't. This is a simplified case of a much more complicated implementation that is auto-generated from macros. I don't have the option of hand modifying the code.
@mariog: I'll filed this issue with the developers on the failure with -O1 since I am not able to reproduce the issue with -O2 or -O3. but have added that info as well. If you can attach a test reproducer with some system details and vs version that'll be great if possible. Anyways, I'll keep you updated as soon as the release with a fix is out, thx.
_Kittur
