icc-8.0 for Linuxfailes while compiling the following code
with -fno-rtti option.
class A {
public:
virtual void fun1 () const = 0;
public:
class B : virtual public A {
public:
virtual void fun2 () const = 0;
public:
class C : virtual public A {
public:
virtual void fun3 () const = 0;
public:
class D : public C, public B {
int main ()
return 0;
return 0;
0 d g++>icc -fno-rtti main.cpp -o main
main.cpp(16): internal error: assertion failed at: "shared/edgcpfe/lower_il.c", line 4681
compilation aborted for main.cpp (code 4)
4 d g++>
4 d g++>
Dear Cheusov,
An emitted compiler assertion is definitely worth a premier support issue. One thought, does the code compile without the -nortti switch?
Max
Everything works fine without -fno-rtti flag.
Is my report enough for this bug to be fixed in future releases?
P.S.
It seems this forum doesn't work with galeon browser under Linux.
Is it InternetExplorer oriented only?
Thanks for report, but problem has been already fixed in 8.1 You can download recent 8.1.021 version from Premier support site to check it.
Max
Max
