$ icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008 Copyright (C) 1985-2013 Intel Corporation. All rights reserved. Although not documented icc accepts both -std=c11 and -std=gnu11, however it doesn't behave as C11 compiler, not even C99. It seems it would fall back to the default (as though I didn't specify -std). This is highly annoying in automatic environments (such as autoconf) where C11 compilers are preferred to C99 compilers, and in particular might fail for C99 code bases.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Could you please provide me a test case to reproduce the issue that you are speaking about?
Sukruth H V
Dear,
I agree this seems to be a bug of ICC. I did not see any document saying about supporting c11 too, it should report something like: icc: command line warning #10159: invalid argument for option '-std'.
I am not sure about new features of c11, but I guess c99 is a subset of c99, so I tested with a C99 feature and reproduce the issue:
#cat foo.c
void foo(int* restrict test) {}
#icc -std=c11 foo.c -c
foo.c(1): error: expected a ")"
compilation aborted for foo.c (code 2)
#icc -std=c99 foo.c -c
#icc -std=wrong_arg foo.c -c
Also, I checked with "-#" and I can see with -std=c11, it is ignored (fall back to default). And with -stc=c99, I can see an additional option (--c99) applied.
I will submit the issue to developer to fix.
Shenghong
FYI. This issue is fixed in v15.0. With C11, it will at least support C99 features.
# source /opt/intel/composer_xe_2013_sp1.1.106/bin/compilervars.sh intel64 # icc -std=c11 temp.c -c temp.c(1): error: expected a ")" void foo(int* restrict test) {} ^ compilation aborted for temp.c (code 2) # icc -v icc version 14.0.1 (gcc version 4.8.0 compatibility) # source /opt/intel/composer_xe_2015.1.133/bin/compilervars.sh intel64 # icc -std=c11 temp.c -c # icc -v icc version 15.0.1 (gcc version 4.8.1 compatibility) # cat temp.c void foo(int* restrict test) {} #
