Intel® C++ Compiler
7956 Discussions
[BUG ?] internal error: assertion failed at: "shared/edgcpfe/statements.c", line 2341
Dmitry_A_1
While compiling the following program with 'icc -c':
#define NEXT_LINE(c)
while ((*(c) != '�') && (*(c) != ' ') && (*(c) != ' ')) {
(c)++;
if (*(c) == ' ') {
(c)++;
} else if (*(c) == ' ') {
(c)++;
if (*(c) == ' ') {
(c)++;&nbs p;
} else {
return -1;
int parse (const char *text)
const char *c = text;
const unsigned int TEMPCHARS = 6;
char buf[TEMPCHARS][96];
NEXT_LINE(c);
return 0;
the compiler fails with the message:
icc-fail.c(24): internal error: assertion failed at: "shared/edgcpfe/statements.c", line 2341
NEXT_LINE(c);
compilation aborted for icc-fail.c (code 4)
This happens on Linux with the compiler version 9.1.045. GNU C 4.1.1 handles this code without any problems.
JenniferJ
I'm able to duplicate the problem. The work around is to remove the variable array or remove the "return -1;" in the define.
If you haven't created an issue at PremierSupport, please do so. I'll create a tracker to the compiler.
Jennifer
Dmitry_A_1
:-) this is not a workaround.
Real workaround is to define NEXT_LINE as usual
#define NEXT_LINE(c) do { /* ...stuff... */ } while (0)
instead of using non-ISO (but widely used by GNU) statement expression:
#define NEXT_LINE(c) ({ /* ...stuff... */ })
