Following code:
extern struct stream_s make_stream(void); struct stream_s { void *clo; /* for strctl */ int(*ctl)(void*, ...); }; struct stream_s make_stream(void) { static int x; return (struct stream_s){.clo = &x}; }
when compiled produces:
$ icc -std=c99 -g -O2 ./crash.c ": internal error: ** segmentation violation signal raised ** Access violation or stack overflow. Please contact Support. compilation aborted for ./crash.c (code 4)
Interestingly, when the function pointer is the first slot in the struct the code will run just fine.
Forgot to post versions:
$ icc -V Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.2.144 Build 20140120 Copyright (C) 1985-2014 Intel Corporation. All rights reserved. FOR NON-COMMERCIAL USE ONLY
I can also reproduce this issue, thanks for reporting. I have escalated to development team. I will inform you when I have an update.
Reddy
Just to let you know, icc 16.0.0.069 Beta Build 20150527 still shows this issue.
Just to let you know, icc 18.0.0 20170811 still shows this issue.
Yes this bug is still open in our database (as cmplrs-626).
There are two possible workarounds, as shown below under #ifdef OK or #ifdef OK2. The bug has to do with placing a temporary declaration which uses x before the declaration of x on the list of static variables. extern struct stream_s make_stream(void); struct stream_s { void *clo; /* for strctl */ int(*ctl)(void*, ...); }; struct stream_s make_stream(void) { #ifdef OK int x; #else static int x; #endif #ifdef OK2 struct stream_s tmp; tmp.clo = &x; return tmp; #else return (struct stream_s){.clo = &x}; #endif }
Topic Options
