Intel® C++ Compiler
Backend signals "Please contact Support" when compiling function with icc 14
Richard_Geary
I get a backend signals / stack overflow error when compiling the attached function with icc 14.
[rgeary@infradev3.skae:~/git/dev]$ icpc13 -c -xc++ rzextr.cpp
[rgeary@infradev3.skae:~/git/dev]$ icpc14.0.0 -c -xc++ rzextr.cpp
": internal error: backend signals
compilation aborted for rzextr.cpp (code 4)
[rgeary@infradev3.skae:~/git/dev:4]$ icpc14.0.1 -c -xc++ rzextr.cpp
": internal error: ** segmentation violation signal raised **
Access violation or stack overflow. Please contact Support.
[rgeary@infradev3.skae:~/git/dev:4]$ icpc14.0.1 --version
icpc (ICC) 14.0.1 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
Richard
SergeyKostrov
Valued Contributor II
I don't think that it will be possible to reproduce the problem unless you provide codes for two external functions used inside of rzextr function.
QIAOMIN_Q_
This is caused by high level optimization in -O2 option, as a workdaround -O0 and -O1 is ok.
I will keep you posted whenever this bug has got some update from the developers's side.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums:                http://software.intel.com/en-us/forums/
SergeyKostrov
>>...This is caused by high level optimization in -O2 option, as a workdaround -O0 and -O1 is ok... It looks interesting since it is Not clear for me if -O2 was used to compile the sources before the compiler crashed. None of optimization options are used and it looks like a default option -O0 was applied. Am I wrong?
QIAOMIN_Q_
Hello Sergey,
Default is O2 ,which enables optimizations for speed. "Some basic loop optimizations such as Distribution, Predicate Opt, Interchange, multi-versioning, and scalar replacements are performed."
The crash happens after the Scalar Replacement phase in O2.
$icpc -c rzextr.cpp -O1(or O0) ,is fine in this case.
Best ,Qiao
SergeyKostrov
>>...Default is O2 ,which enables optimizations for speed... Yes, you're correct and thanks for the correction.
SergeyKostrov
This is simply to inform that there are strange delays with refreshing the webpage after Submit button is pressed...
Richard_G_4
Hi Qiaomin and Sergey,
Thanks for your fast response, our code compiles with -O1.
Richard
QIAOMIN_Q_
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
$ icpc -c -xc++ rzextr.cpp -O1 -opt-report=3
is fine for me ,what's your gcc version?
Regards, Qiao
Richard_G_4
Hi Qiao,
I only get the internal error with -O2 or -O3, so I can use -O1 for this file as a workaround. This is RHEL5, the system gcc is 4.1.2, but I've tested gcc 4.7.2 with -gxx-name and get the same result.
$ gcc --version
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-54)
Richard
QIAOMIN_Q_
Hello Richard,
This bug has been fixed in the latest compiler SP1 Update3 ,Version 14.0.3.174 Build 20140422 .I have confirmed that .Please have a check .
Thank you.
QIAOMINQ.
Tools Knowledge Base:           http://software.intel.com/en-us/articles/tools
Richard_G_4
Fix confirmed, thanks!
