I get a backend signals / stack overflow error when compiling the attached function with icc 14.
[rgeary@infradev3.skae:~/git/dev]$ icpc13 -c -xc++ rzextr.cpp
[rgeary@infradev3.skae:~/git/dev]$ icpc14.0.0 -c -xc++ rzextr.cpp
": internal error: backend signals
compilation aborted for rzextr.cpp (code 4)
[rgeary@infradev3.skae:~/git/dev:4]$ icpc14.0.1 -c -xc++ rzextr.cpp
": internal error: ** segmentation violation signal raised **
Access violation or stack overflow. Please contact Support.
[rgeary@infradev3.skae:~/git/dev:4]$ icpc14.0.1 --version
icpc (ICC) 14.0.1 20131008
Copyright (C) 1985-2013 Intel Corporation. All rights reserved.
Richard
This is caused by high level optimization in -O2 option, as a workdaround -O0 and -O1 is ok.
I will keep you posted whenever this bug has got some update from the developers's side.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums: http://software.intel.com/en-us/forums/
Hello Sergey,
Default is O2 ,which enables optimizations for speed. "Some basic loop optimizations such as Distribution, Predicate Opt, Interchange, multi-versioning, and scalar replacements are performed."
The crash happens after the Scalar Replacement phase in O2.
$icpc -c rzextr.cpp -O1(or O0) ,is fine in this case.
Best ,Qiao
Hi Qiaomin and Sergey,
Thanks for your fast response, our code compiles with -O1.
Richard
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
$ icpc -c -xc++ rzextr.cpp -O1 -opt-report=3
is fine for me ,what's your gcc version?
Regards, Qiao
Hi Qiao,
I only get the internal error with -O2 or -O3, so I can use -O1 for this file as a workaround. This is RHEL5, the system gcc is 4.1.2, but I've tested gcc 4.7.2 with -gxx-name and get the same result.
$ gcc --version
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-54)
Richard
Fix confirmed, thanks!
Hello Richard,
This bug has been fixed in the latest compiler SP1 Update3 ,Version 14.0.3.174 Build 20140422 .I have confirmed that .Please have a check .
Thank you.
QIAOMINQ.
Tools Knowledge Base: http://software.intel.com/en-us/articles/tools
