Dear All,
I am new to assembly language. Using, GCC on Windows 7 with Mingw. Using following command, using source file Hello.c,
got the Disassembley on the Hello_asm.txt ( can see the assembly content..believe it is in Intel format).
objdump -M intel -S -d Hello.o >Hello_asm.txt
Fine. Now, another secnario, if the use the Intel C++ compiler on my Windows 7 PC, Without Visual studio environment, compile Hello.c and get the Assembly file.. believe it will created with .asm ( Hello.asm.). My doubt : Hello.asm ( Intel) and Hello_asm.txt (GCC) will have same assembly language content for the x86 platform/Windows. Irrespective of whether an exe file created or not (from Obj file or assembler)
Please advise. Am i missing any info.
Cheers!
Chandra
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Chandra,
If you compared instructions to instructions, then the 2 compilers might not generate the same asm, but it should run. Also, you can mix-match objects compiled with Intel compiler with MS on Windows or Gnu on Linux.
Viet Hoang
Dear Viet Hoang,
Got your point. Will look into.. and update here.
Thanks a lot.
-cheers! chandra
Windows and Linux use different conventions for passing arguments in registers to functions, and this difference can make the two assembler files substantially different. There are utilities available for porting assembler files; see, for example, http://www.agner.org/optimize/#objconv .
Additionally, Linux systems often require code to be written in Position Independent Code (PIC) format, whereas Windows does not (code relative to the VM's location 0).
Jim Dempsey
Thanks all for replies. Understand, Linux and Windows are different.At the moment, i am comparing GCC (Windows/MINGW/GCC) and
Intel (Windows - Intel C/C++ compiler). Will update soon.
Thanks. Cheers!
chandra
Dear All,
i am try to explore from 2 type of assembly output for our project.
GCC (Windows/MINGW/GCC) / gcc -S -masm = intel hello.c
Intel (Windows - Intel C/C++ compiler - IA32 Visual studio environment ) / icl - c -S -o hello.s hello.c
Objective: Our project (pure 32 bit C application. ) is at beginning stage. It should run on cross platform with minimum effort on Windows, MAC OS, Linux (ARM), Android (ARM). The final executable should converted from assembly (after some optimization)..
1 ) So, in this how Intel C/C++ compiler (output assembly) will be better than GCC. (AT & T syntax vs Intel syntax)
2 ) Believe, Intel do not have ARM compiler, is there any method to convert from Intel syntax to ARM (like Raspberry Pi)
3) Seeing from simple - Hello World program... the Intel syntax gives more verbose which will helpful to understand assembly. (attached both files).
(the question slight become complex than originally). So, at the end, we have to choose either GCC or Intel.Any thoughts useful :)
Cheers!
chandra
The C source file can be written to be compiled on, or targeted to, a specific platform. Some of your source files may require conditional compilation directives to enable/disable sections of code and/or include files. The generated executable generally will not be portable either due to C Runtime differences or Instruction Set architecture differences (IA32 verses ARM).
As you can see from your two text files the GCC built program is using its _puts CRTL function, whereas the Intel compiler is using ___stdio_common_vfprintf (in addition to making calls to additional functions).
To aid in making "transportable code", I recommend renaming your "main" to "my_main", then creating a new main that simply calls my_main with the same arguments. This will isolate any system dependent initialization (and shutdown) code.
You can also think if it is appropriate to do this with other CRTL functions, such as printf.
Jim Dempsey
