Intel® C++ Compiler
BenchFFT compilation fails
perfwise
I'm trying to build BenchFFT:
http://www.fftw.org/benchfft/
but the compilation fails.  I'm assuming at some point it worked.. with GNU or Intel compilers.  Any recommendations as to getting it working is greatly appreciated.
perfwise
pbkenned1
What compiler versions and what compilation and linking switches?  What OS release?  What CPU target?  What is the comp fail?
Patrick
chetan_p_
Hi .
I am trying to run benchfft with linking Intel-mkl but I am getting error with ” undefined reference to `zfft1d_'
System Details:
OS: Ubuntu 16.04
GCC: gcc version 5.4.0 20160609
ICC: icc version 17.0.0
Note: File benchfftw_test_mkl.c is attached with this report
source /opt/intel/mkl/bin/mklvars.sh intel64
gcc -lmkl_core  -ldl -lpthread -lm benchfftw_test_mkl.c
Error:
/tmp/ccsL8FHu.o: In function `main':
benchfftw_test_mkl.c:(.text+0xa): undefined reference to `zfft1d_'
collect2: error: ld returned 1 exit status
Contents of benchfftw_test_mkl.c is as follows
#line 10867 "configure"
/* confdefs.h.  */
#define PACKAGE_NAME ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define PACKAGE_STRING ""
#define PACKAGE_BUGREPORT ""
#define PACKAGE "benchfft"
#define VERSION "3.1"
#ifdef __cplusplus
#include <stdlib.h>
#endif
#define F77_FUNC(name,NAME) name ## _
#define F77_FUNC_(name,NAME) name ## _
#define STDC_HEADERS 1
#define HAVE_SYS_TYPES_H 1
#define HAVE_SYS_STAT_H 1
#define HAVE_STDLIB_H 1
#define HAVE_STRING_H 1
#define HAVE_MEMORY_H 1
#define HAVE_STRINGS_H 1
#define HAVE_INTTYPES_H 1
#define HAVE_STDINT_H 1
#define HAVE_UNISTD_H 1
#define HAVE_MALLOC_H 1
#define HAVE_SYS_TIME_H 1
#define HAVE_ALLOCA_H 1
#define HAVE_STDDEF_H 1
#define HAVE_LIBINTL_H 1
#define TIME_WITH_SYS_TIME 1
#define HAVE_ALLOCA 1
#define HAVE_MALLOC 1
#define HAVE_VPRINTF 1
#define HAVE_LIBM 1
#define HAVE_GETTIMEOFDAY 1
#define HAVE_DRAND48 1
#define HAVE_HYPOT 1
#define HAVE_SQRT 1
#define HAVE_STRTOD 1
#define HAVE_MEMSET 1
#define HAVE_MEMALIGN 1
#define HAVE_DECL_DRAND48 1
#define HAVE_DECL_HYPOT 1
#define HAVE_LIBPTHREAD 1
#define HAVE_LIBDL 1
#define HAVE_FFTW3_H 1
/* end confdefs.h.  */
/* Override any gcc2 internal prototype to avoid an error.  */
#ifdef __cplusplus
extern "C"
#endif
/* We use char because int might match the return type of a gcc2
   builtin and then its argument prototype would still apply.  */
char zfft1d_ ();
#ifdef F77_DUMMY_MAIN
#  ifdef __cplusplus
     extern "C"
#  endif
   int F77_DUMMY_MAIN() { return 1; }
#endif
int
main ()
zfft1d_ ();
  return 0;
