The Visual Studio 2022 17.5 update will break your compilation if you are still using ICX 2022 versions due to this check in yvals_core.h
#if __clang_major__ < 15
_EMIT_STL_ERROR(STL1000, "Unexpected compiler version, expected Clang 15.0.0 or newer.");
The Intel oneAPI C++ Compiler(icx) 2022 compiler is incompatible with Visual Studio 2022 17.5 version.
You can try the supported Visual Studio version for using the icx 2022 compiler.
Please refer to the below link for more details.
Thanks and Regards,
Pendyala Sesha Srinivas
Has the information provided above helped? If yes, could you please confirm whether we can close this thread from our end?
Thanks and Regards,
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
