Below is Bitfield code -
--------bitfield.c---------
#include
struct
int bit1 : 1;
int bit2 : 1;
} bits;
bits.bit1 = 1;
bits.bit2 = 1;
int main()
return 0;
When using ICC-v11.0 on Linux x86_64, I get below messages -
bitfield.c(9): warning #77: this declaration has no storage class or type specifier
bits.bit1 = 1;
bitfield.c(9): error: declaration is incompatible with "struct bits" (declared at line 7)
bits.bit1 = 1;
bitfield.c(9): error: expected a ";"
bits.bit1 = 1;
bitfield.c(10): warning #77: this declaration has no storage class or type specifier
bits.bit2 = 1;
bitfield.c(10): error: expected a ";"
bits.bit2 = 1;
compilation aborted for bitfield.c (code 2)
I did try with unsigned too.
~BR
#include
struct
int bit1 : 1;
int bit2 : 1;
} bits;
bits.bit1 = 1;
bits.bit2 = 1;
int main()
return 0;
bits.bit1 = 1;
bits.bit1 = 1;
bits.bit1 = 1;
bits.bit2 = 1;
bits.bit2 = 1;
~BR
The problem is that you can't put assignment statements like "bits.bit1 = 1;" at global scope.
You either need to move them inside main() or initialize the structure using an aggregate initializer
list, i.e.:
struct
int bit1 : 1;
int bit2 : 1;
} bits = { 1, 1 };
Judy
list, i.e.:
struct
int bit1 : 1;
int bit2 : 1;
} bits = { 1, 1 };
Judy
Quoting - Judith Ward (Intel)
list, i.e.:
struct
int bit1 : 1;
int bit2 : 1;
} bits = { 1, 1 };
Judy
list, i.e.:
struct
int bit1 : 1;
int bit2 : 1;
} bits = { 1, 1 };
Judy
You also have the additional problem that a 1 bit int will hold values of 0 and -1.
If you want values of 0 and 1 then use "unsigned bit1: 1"
Jim
list, i.e.:
struct
int bit1 : 1;
int bit2 : 1;
} bits = { 1, 1 };
Judy
list, i.e.:
struct
int bit1 : 1;
int bit2 : 1;
} bits = { 1, 1 };
Judy
~BR
