Intel® C++ Compiler
Boost 1.65.1 with Intel C++ 18.0 on Windows with Visual Studio 15.4.5
Sergey_quixoticaxis_
Did anyone manage to compile Boost 1.65.1 with Intel C++ 18.0 and Visual Studio 15.4.5? I somehow successfully compiled 1.65.1 with prior versions of VS2017 but now it fails.
More specifically, when launching "b2 address-model=64 toolset=intel-18.0-vc14 cxxflags=/Qstd=c++17 --build-type=complete link=static --with-coroutine --with-filesystem --with-context --with-log stage" build process doesn't find "icl" while it's accessible from the same console.
Any help is appreciated.
jimdempseyatthecove
Are your sure icl is being invoked instead of MS VC++ (expected to be located in toolset=intel-18.0-vc14)?
Jim Dempsey
Jim Dempsey
I suppose it's trying to use icl because the error I get is "icl is not recognized as an internal or external command".
jimdempseyatthecove
It would appear that the PATH to icl was not setup properly. As a diagnostic (I am assuming b2 is a batch or makefile or other shell script file), just prior to it invoking icl, insert an
echo $PATH
into the script. Then verify that icl is located in PATH (at the place in the script file that issues icl).  A common cause for such error is messing semicolon (;).
Jim Dempsey
echo $PATH
Jim Dempsey
b2 is an executable, so I can't insert echo anywhere. Well, I probably can, but for this to work I'll need to more or less understand how Boost.Build is internally working, and currently I can't afford it (no time). I though that someone might know how to build it because Boost 1) is popular, 2) is often a source compilers are tested on.
AndrewC
New Contributor III
- does Boost 1.65.1 have support for the 18.0 toolset? Each intel toolset needs to be explicitly supported.
- if it does, then open a Visual Studio 2017 x64 native tools command prompt
- type icl -v and check version
- run the boost build from that command prompt.
  1. I don't know if it is explicitly supported. I managed to build the libraries I need with toolset=intel-18.0-vc14 (and b2 didn't tell me that it can't understand toolset which is the case for, for example, intel-19.0)
  2. Native VS2017 x64 command prompt does not have icl in the path. But Boost (according to Intel papers) should be build using Intel environment.
It's not too important for me because I already have all compiled libraries but still.
