I am using lockfree queue from boost:
#include <boost/lockfree/queue.hpp> #include <boost/atomic.hpp> boost::lockfree::queue<int> queue(10000);
Works fine with GCC compiler, but not with Intel. I get the following error:
In file included from /usr/include/boost/lockfree/queue.hpp(24), from /home/martin/projects/EGO/BLAS-join3/cmake/main.cpp(5): /opt/gcc6.1.0/usr/local/bin/../include/c++/6.1.0/atomic(178): error: static assertion failed with "std::atomic requires a trivially copyable type" static_assert(__is_trivially_copyable(_Tp), ^ detected during instantiation of class "std::atomic<_Tp> [with _Tp=boost::lockfree::detail::tagged_index]" at line 584 of "/usr/include/boost/lockfree/detail/freelist.hpp" /opt/gcc6.1.0/usr/local/bin/../include/c++/6.1.0/atomic(178): error: static assertion failed with "std::atomic requires a trivially copyable type" static_assert(__is_trivially_copyable(_Tp), ^ detected during: instantiation of class "std::atomic<_Tp> [with _Tp=boost::lockfree::detail::tagged_ptr<boost::lockfree::detail::freelist_stack<boost::lockfree::queue<int, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node, std::allocator<boost::lockfree::queue<int, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node>>::freelist_node>]" at line 244 of "/usr/include/boost/lockfree/detail/freelist.hpp" instantiation of class "boost::lockfree::detail::freelist_stack<T, Alloc> [with T=boost::lockfree::queue<int, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node, Alloc=std::allocator<boost::lockfree::queue<int, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node>]" at line 121 of "/usr/include/boost/lockfree/queue.hpp" instantiation of class "boost::lockfree::queue<T, A0, A1, A2> [with T=int, A0=boost::parameter::void_, A1=boost::parameter::void_, A2=boost::parameter::void_]" at line 38 of "/home/martin/projects/EGO/BLAS-join3/cmake/main.cpp" /opt/gcc6.1.0/usr/local/bin/../include/c++/6.1.0/atomic(178): error: static assertion failed with "std::atomic requires a trivially copyable type" static_assert(__is_trivially_copyable(_Tp), ^ detected during: instantiation of class "std::atomic<_Tp> [with _Tp=boost::lockfree::detail::tagged_ptr<boost::lockfree::queue<int, boost::parameter::void_, boost::parameter::void_, boost::parameter::void_>::node>]" at line 463 of "/usr/include/boost/lockfree/queue.hpp" instantiation of class "boost::lockfree::queue<T, A0, A1, A2> [with T=int, A0=boost::parameter::void_, A1=boost::parameter::void_, A2=boost::parameter::void_]" at line 38 of "/home/martin/projects/EGO/BLAS-join3/cmake/main.cpp" compilation aborted for /home/martin/projects/EGO/BLAS-join3/cmake/main.cpp (code 2) make[2]: *** [CMakeFiles/blasJoin.dir/main.cpp.o] Fehler 2 make[1]: *** [CMakeFiles/blasJoin.dir/all] Fehler 2 make: *** [all] Fehler 2
I am using the following flags in CMAKE:
if ("${CMAKE_CXX_COMPILER_ID}" STREQUAL "GNU") set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -march=knl -mtune=knl -fpic -ffast-math -DNDEBUG -O3 -DNDDEBUG -fopenmp -lmkl_core -lmkl_intel_lp64 -lmkl_intel_thread -liomp5 -lboost_system") elseif ("${CMAKE_CXX_COMPILER_ID}" STREQUAL "Intel") set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -xmic-avx512 -qopenmp -DNDEBUG -O3 -lmkl_intel_thread -liomp5 -lpthread -lmkl_core -lmkl_intel_lp64 -lboost_system") endif()
OS: centos-release-7-4.1708.el7.centos.x86_64
Intel Compiler 18.0.2 20180210
GCC version: 6.1.0
Boost version: 1.66
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you create a preprocess file (main.i) and provide it to us for investigation?
Viet
Martin P. wrote:
I am not sure, what you mean with "preprocess file" or "main.i".
It means compilation with -P option and you will see *.i files.
I've compiled the sources with the -EP -P compile option, described in:
https://software.intel.com/en-us/articles/how-to-create-a-preprocessed-file-i-file
Topic Options
