[cpp]struct Tester { void test(int i) { // Five cases to trigger branch table optimisation. switch(i) { case 1: break; case 2: break; case 3: break; case 4: break; case 5: break; } } }; int main() { Tester tester; tester.test(1); }[/cpp]
[plain]0x0000000100000ee8 <_ZN6Tester4testEi+0>: push %rbp 0x0000000100000ee9 <_ZN6Tester4testEi+1>: mov %rsp,%rbp 0x0000000100000eec <_ZN6Tester4testEi+4>: sub $0x20,%rsp 0x0000000100000ef0 <_ZN6Tester4testEi+8>: mov %rdi,-0x20(%rbp) 0x0000000100000ef4 <_ZN6Tester4testEi+12>: mov %esi,-0x10(%rbp) 0x0000000100000ef7 <_ZN6Tester4testEi+15>: mov -0x10(%rbp),%eax 0x0000000100000efa <_ZN6Tester4testEi+18>: mov %eax,-0x18(%rbp) 0x0000000100000efd <_ZN6Tester4testEi+21>: dec %eax 0x0000000100000eff <_ZN6Tester4testEi+23>: cmp $0x4,%eax 0x0000000100000f02 <_ZN6Tester4testEi+26>: ja 0x100000f1d <_ZN6Tester4testEi+53> 0x0000000100000f04 <_ZN6Tester4testEi+28>: mov -0x18(%rbp),%eax 0x0000000100000f07 <_ZN6Tester4testEi+31>: dec %eax 0x0000000100000f09 <_ZN6Tester4testEi+33>: lea -0x28(%rip),%rdx # 0x100000ee8 <_ZN6Tester4testEi> 0x0000000100000f10 <_ZN6Tester4testEi+40>: lea -0x20(%rip),%rcx # 0x100000ef7 <_ZN6Tester4testEi+15> 0x0000000100000f17 <_ZN6Tester4testEi+47>: add (%rdx,%rax,8),%rcx 0x0000000100000f1b <_ZN6Tester4testEi+51>: jmpq *%rcx[/plain]The final jump instruction refers to an invalid location. I presume this is the branch following the table lookup. However, the (relative + rcx) target appears to be computed by dereferencing the code segment at 0x100000ee8 (or, in this example, 0x100000ee8 + 8): not the branch table?
[plain]0x0000000100000dc3 <_ZN6Tester4testEi+35>: lea 0x10(%rip),%rdx # 0x100000dda <_ZN6Tester4testEi+58> 0x0000000100000dca <_ZN6Tester4testEi+42>: lea -0x22(%rip),%rcx # 0x100000daf <_ZN6Tester4testEi+15> 0x0000000100000dd1 <_ZN6Tester4testEi+49>: add (%rdx,%rax,8),%rcx 0x0000000100000dd5 <_ZN6Tester4testEi+53>: jmpq *%rcx 0x0000000100000dd7 <_ZN6Tester4testEi+55>: leaveq 0x0000000100000dd8 <_ZN6Tester4testEi+56>: retq 0x0000000100000dd9 <_ZN6Tester4testEi+57>: nop 0x0000000100000dda <_ZN6Tester4testEi+58>: sub %al,(%rax)[/plain]Note the forward reference to 0x100000dda, which is the beginning of data and presumably encodes the branch table.
The index range check is using eax (32-bit)
eax is diddled with following range check
The final jump has SIB with rax (64-bit)
I think the eax diddling bunged up the high order 32-bits of rax.
Jim Demspey
The problem you are seeing looks like an issue with MacOS 10.6.3 and the linker from Xcode 3.2.x.
The same object files, being linked with a previous linker (from 10.5.8) works fine on any version of macOS, including 10.6.3. We are discussion this issue with Apple engineer to understand the problem.
I'll post an update once we have a resolution.
The problem is in the linker from xcode3.2.2 which has a bug with resolving relocations for symbols with names that start with 'L'.
By convention assembler suppresses all symbols with name starts with 'L' so when using gcc or (icc with -use_asm option) the linker will not see these symbols.
The fix for this problem will be available in a future update to the compiler product.
The work arounds are:
1) Use Xcode 3.2.1 with 11.1 compiler.
2) Use 11.1 compiler with the option -use-asm with Xcode 3.2.2, 3.2.3, 3.2.4.
3) Use Intel Composer XE.
- It should fix most cases but there are some cases when even generating object file through external assembler L* symbols still may appear in object file. Those cases are usually constant string literals placed in cstring section
We are not planning to work around this linker bug in the 11.1 compiler due to the complexity of the workaround which might reduce the stability of the 11.1 product.
Xcode 3.2.5 was released last week.This version should have the linker fixes for several linker bugs seen in previous version as noted in this thread.
The recommendation is to use Xcode 3.2.5 with Intel compiler.
