Intel® C++ Compiler
7782 Discussions
Bug? Binary literals are supported for old c++
Ben_Ari__Doron
I use this compilation lines:
icpc -std=c++98 -pedantic-errors integers.cc
To compile the following piece of code:
int i = 0b10101;
std::cout << i << std::endl;
It compiles well and works perfectly (the output is 21).
To verify that i use the correct compiler flags I add the following line
auto g () {
    return 2.3;
And indeed in this case I get the expected compiler error when using the compiler flags.
Binary literals is a feature that is supposed to exist only since C++14. So why does my code of binary literals compile? Is it icpc bug?
(With g++ and same flags, it works as expected and does not compile with the binary literals)
Viet_H_Intel
Seems like icpc didn't catch this case of -std=c++98.
