Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
7677 Discussions
Bug: C++11 non-POD thread_local causes reinitialization of non-thread_local static vars?
Daniel_V_2
Using a thread_local non-POD type seems to cause all static but non-thread_local variables (which should only be initialized once) to be reconstructed on every access to the thread_local variable.
Observe:
// icpc version 15.0.0 (gcc version 4.9.0 compatibility)
// icpc -std=c++11 tls.cpp && ./a.out
// -- Expected output --
// MakePointer()
// MyInt constructor <pointer>
// -- Actual output --
// MakePointer()
// MakePointer() x 10 (= numReps)
#include <cstdio>
// non-POD type
struct MyInt
	MyInt()
		printf("MyInt constructor %p\n", this);
	int v = 1;
// should be called exactly once
inline void *MakePointer()
	printf("MakePointer()\n");
	return nullptr;
// normal static initialization, should happen ONCE
static void *pointer = MakePointer();
// thread_local non-POD variable, should be constructed as many times as there are threads
static thread_local MyInt v1;
const int numReps = 10;
int main(int argc, char const *argv[])
	for (int i = 0; i < numReps; ++i)
		++v1.v; // each access seems to reinitialize all static variables?!?
	return 0;
We have a static variables 'pointer' which should be constructed exactly once (twice if you count zero-initialization of statics and globals) and a non-POD thread_local variables 'v1' which - as this example only used a single thread - be constructed once as well.
Unfortunately - at least using icpc version 15.0.0 (gcc version 4.9.0 compatibility) - every access to the thread_local variable 'v1' seems to cause reinitialization of 'pointer'. This is both a performance problem (depending on the cost of initialization of all statics in your translation unit) and a correctness problem (in my actual use case a static variable shared between threads got re-initialized by later threads while it was being used by earlier ones).
When I change the thread_local 'v1' to a POD-type (e.g. int), this phenomenon no longer seems to occur.
Shenghong_G_Intel
Hi Daniel,
Could you please upgrade your compiler? It works with latest 15.0 U2 release (and 15.0 U1 release). See below:
$ source /opt/intel/composer_xe_2015.0.090/bin/compilervars.sh intel64
$ icc temp.cpp -std=c++11 && ./a.out
MakePointer()
MyInt constructor 0x7f3c2fcd9718
MakePointer()
MakePointer()
MakePointer()
MakePointer()
MakePointer()
MakePointer()
MakePointer()
MakePointer()
MakePointer()
MakePointer()
$ source /opt/intel/composer_xe_2015.1.133/bin/compilervars.sh intel64
MakePointer()
MyInt constructor 0x7fae6756f718
$ source /opt/intel/composer_xe_2015.2.164/bin/compilervars.sh intel64
MakePointer()
MyInt constructor 0x7f1bb853a718
Shenghong
