Intel® C++ Compiler
7929 Discussions
Bug Report: icc 19 emitting incorrect warnings for C11 atomics
NathanH
Putting this in the C++ forum as there is no forum for the C compiler.
We have a code that support C11 and it needs to compilable (without warnings) with icc. The problem is that we see warnings like this when using the atomic types (ex. _Atomic int) with the atomic function (ex. atomic_exchange). These warnings suggest that icc is not correctly defining the C11 atomic functions.
Example code (valid C11):
#include <stdatomic.h>
int main (int argc, char *argv[]) {
  _Atomic int foo = 0;
  atomic_exchange (&foo, 1);
  return 1;
Warnings:
icc icc_atomic_reproducer.c
icc_atomic_reproducer.c(6): warning #2330: argument of type "_Atomic(int) *" is incompatible with parameter of type "volatile void *" (dropping qualifiers)
atomic_exchange (like all atomics) is defined to be a _Generic function with the first argument of the form volatile _Atomic <something>*.
This warning shows that icc is in clear violation of ISO C11. This warning appears in icc 18 as well.
PrasanthD_intel
Hi Nathan,
We have tried the reproducer code you have given with icc(19.1.1.217) and we are getting an error as below:
$ icc atomic_test.c
atomic_test.c(7): error: identifier "_Atomic" is undefined
atomic_test.c(7): error: expected a ";"
atomic_test.c(11): error: identifier "foo" is undefined
You have mentioned that you are getting only a warning.
Can you confirm that the reproducer code is complete? or are we missing anything?
Prasanth
Viet_H_Intel
We will addressed this issue in the next release.
Viet_H_Intel
This issue is fixed in oneAPI 2021.2. Hence, we are going to close this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
$ icc test.c -V
Intel(R) C Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.2.0 Build 20210228_000000
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
Edison Design Group C/C++ Front End, version 5.1 (Feb 28 2021 02:56:56)
Copyright 1988-2019 Edison Design Group, Inc.
GNU ld version 2.30-58.el8
$ cat test.c
 return 1;
