Intel® C++ Compiler
Bug in Intel ICC V11.1 compiler?
jianni
I've run into what I believe to be a bug in Intel's standard C++ library implementation under linux-Intel64. I'd like to know if this is the case, or if I'm doing something incorrectly. I've managed to distill the problem into a short C++ source file (see below).
The attached program outputs the following on GCC and Intel:
> g++ test.cpp -o test.gcc
> icpc test.cpp -o test.icc
> ./test.gcc
(1,-1)
(2,-2)
(3,-3)
(4,-4)
> ./test.icc
(2.07468e-317,2.33291e-310)
The GCC results are what I would expect to get, the Intel results are completely wrong.
> icpc -v
Version 11.1
> cat test.cpp
#include
#include
#include
#include
#include
int main( int argc, char* argv[] ) {
typedef std::complex< double > Complex;
std::vector< Complex > v;
v.push_back( Complex( 1, 1 ) );
v.push_back( Complex( 2, 2 ) );
v.push_back( Complex( 3, 3 ) );
v.push_back( Complex( 4, 4 ) );
std::transform( v.begin(), v.end(), v.begin(), std::conj< double > );
std::copy( v.begin(), v.end(),
std::ostream_iterator< Complex >( std::cout, "\\n" ) );
return 0;
Please advise.
mecej4
Black Belt
There is something amiss with your setup. On Suse 11.1-amd64, I get
[bash]~/LANG> icpc -V cmplx.C
Intel C++ Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1    Build 20100203 Package ID: l_cproc_p_11.1.069
Copyright (C) 1985-2010 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY
Edison Design Group C/C++ Front End, version 3.10.1 (Feb  3 2010 19:19:06)
Copyright 1988-2007 Edison Design Group, Inc.
GNU ld (GNU Binutils; devel:gcc / openSUSE_11.1) 2.20.0.20100122-33
$ ./a.out
(4,4)
(4,4)
(4,4)
(4,4)
[/bash]
Judith_W_Intel
It's not a problem in the standard library since Intel uses whatever library is on your system.
It looks like a compiler bug that is sensitive to inline level, i.e.:
sptxl8-23> icpc -inline-level=1 t.cpp && a.out
(1,-1)
(2,-2)
(3,-3)
(4,-4)
sptxl8-24> icpc -inline-level=2 t.cpp && a.out
(1.1267e-266,2.67007e-307)
I will make sure someoneenters this in our bug database.
It stillexists in our development compiler.
And thanks for the example.
Judy
JenniferJ
Hello everyone,
this issue has been fixed and the fix is in the Intel C++ Composer XE update 2.
Please download it from the Registration Center.
Jennifer
