Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
7725 Discussions
Bug in lambdas ICC Update 10 on Windows
Dix_Lorenz
Hi all,
the following code crashes with the new compiler update (actually, it also crashed in Update 9). InDoSomethingWithAnInt "this" has a Value of "0xcdcdcdcd"...
(sorry for the formatting, no idea how to do it better in here)
#include "stdafx.h"
#include
#include
#include
#include
#include
using namespace std;
namespace NS1 {
class Dispatcher {
public:
void Dispatch(function inFunction);
void Dispatcher::Dispatch(function inFunction)
inFunction();
class SomeClass {
public:
void Pass(int i) { cout << i << endl; }
namespace N2 {
class Interior {
public:
Interior() : mSomeClass(new SomeClass) {}
void DoSomething();
void DoSomethingWithAnInt(int i);
private:
unique_ptr mSomeClass;
void Interior::DoSomething()
NS1::Dispatcher theDispatcher;
vector v;
for (int i = 0; i < 10; ++i)
v.push_back(i);
theDispatcher.Dispatch([=](){
for_each(v.begin(), v.end(), [=](int i){
DoSomethingWithAnInt(i);
void Interior::DoSomethingWithAnInt(int i)
mSomeClass->Pass(i);
int _tmain(int argc, _TCHAR* argv[])
cout << "Hello World." << endl;
N2::Interior theInterior;
theInterior.DoSomething();
return 0;
Om_S_Intel
I could not compile the test case. Could you please help me with stdafx.h and any other file that is required to compile it?
Georg_Z_Intel
Thank you for reporting this finding. I was able to reproduce it and filed a defect ticket for engineering (DPD200285602). As soon as I learn more I'll let you know.
As workaround I only can offer you to use capture by reference (theDispatcher.Dispatch([&](){...); at least it would fit to your example.
Georg Zitzlsberger
Georg_Z_Intel
this problem has been fixed for the next update release, Intel Composer XE 2011 Update 12.
Georg Zitzlsberger
