icc 13.0.1 20121010, 64-bit Linux
Test cases are from the Linux kernel.
1. Consider this simple program. icc miscompiles it.
int count(int i)
if (i++ >= 0x7FFFFFFF)
__builtin_trap();
return i;
#include
#include
int main(int argc, char **argv)
int x = atoi(argv[1]);
printf("%d\n", count(x));
This is the expected result, compiled with -O0.
$ icc -O0 t.c
$ ./a.out 0
1
This might be an icc bug with -O2.
$ icc -O2 t.c
$ ./a.out 0
Segmentation fault (core dumped)
icc incorrectly folds (i++ >= 0x7FFFFFFF) into true. Do you happen to know why?
2. Consider a slightly different version.
int count(int i, int max)
if (i++ >= max)
__builtin_trap();
return i;
#include
#include
int max = atoi(argv[2]);
printf("%d %d %d\n", x, max, count(x, max));
The behavior changes from -O0 to O2.
$ icc -O0 t.c
$ ./a.out 2147483647 2147483647
$ icc -O2 t.c
2147483647 2147483647 -2147483648
icc turns (i++ >= max) into (++i > max). Strictly speaking, this is not a bug in icc as per the C standard, because
1) signed integer overflow is undefined behavior, and
2) icc is allowed to assume i++ never overflows.
My question is, does icc provide anything like gcc's -fno-strict-overflow or -fwrapv to disable such optimizations based on signed integer overflow?
thank you for reporting this! I think both cases are a bug (likely the same one) and filed a defect ticket for engineering (DPD200240103). I'm going to let you know about the progress.
Regarding...
- -fno-strict-overflow: That's already supported with Intel(R) Composer XE 2011 Update 10 and higher.
- -fwrapv: We already have a feature request for it but no plan on the horizon yet. I've added you and am going to report here once it's available.
Georg Zitzlsberger
Thanks for the update!
I've just seen the official validation of the ticket (DPD200240103) for this problem. Starting already with Intel(R) Composer XE 2013 SP1, this problem is fixed now.
Georg Zitzlsberger
Thanks!
