Intel® C++ Compiler
7956 Discussions
[Bug report] Compiler error for nested template parameter deduction
Daniel_A_1
Dear all,
a minimal example of the code I was trying to compile is
 #include <type_traits>
 template <bool... Values> struct BoolStorage;
 struct all_true
   static constexpr bool value = std::is_same<BoolStorage<Values..., true>,
                                              BoolStorage<true, Values...>>::value;
 struct enable_if_all : std::enable_if<all_true<Values...>::value> {};
 template <int dim>
 class FiniteElement
 template <int dim>
 class FESystem
   public:
   template <class... FEPairs,
                      typename = typename enable_if_all<(std::is_same<typename std::decay<FEPairs>::type,
        FiniteElement<dim>*>::value)...
        >::type>
   FESystem(FEPairs &&... fe_pairs)
 int main()
   FiniteElement<2> fe;
   FESystem<2> fe_system(&fe, &fe);
This should be C++11 compliant but I get the following errors with ICC18:
test_fe_system_constructor.cc(34): error: no instance of constructor "FESystem<dim>::FESystem [with dim=2]" matches the argument list
            argument types are: (FiniteElement<2> *, FiniteElement<2> *)
test_fe_system_constructor.cc(20): note: this candidate was rejected because mismatch in count of arguments
  class FESystem
  class FESystem
test_fe_system_constructor.cc(27): note: this candidate was rejected because at least one template argument could not be deduced
compilation aborted for test_fe_system_constructor.cc (code 2)
Best,
Daniel
Viet_H_Intel
Thanks for reporting a problem and provided a test case. I will report it to our developer.
Viet Hoang
Viet_H_Intel
Hi Daniel,
I filed a bug report: #CMPLRS-46357
Viet Hoang
Daniel_A_1
This is fixed in the ICC19 beta. Best, Daniel
