Intel® C++ Compiler
7956 Discussions
Bug report - I don't know this error or it's normal
Komarov__Alexander
I optimized my code and after that some operation. I have a mistake of accuracy with original version.
I wrote this example that repeats a mistake of the accuracy. But I don't know this bug or it's normal.
[cpp]
#include <iostream>
#include <stdlib.h>
#include <vector>
#include <stdio.h>
using namespace std;
double bringHistSpec(const double *my_hist) {
    const int NLI = 256;
    int n = 1000;
   double sump_ = 300;
   double p[NLI];
   for (int i = 0; i < NLI; i++) {
      p = my_hist;
      p=p * n / sump_;
   double sump = 0.0;
      sump += p;
   return sump;
double bringHistSpecOrig(const double *my_hist) {
   int n = 1000;
   double sump_ = 300;
   double p[NLI];
   p = my_hist;
   //for (int i = 0; i < NLI; i++) {
   // p=p * n / sump_;
   double sump = 0.0;
      p=p * n / sump_;
      sump += p;
   return sump;
int main() {
   const int sizeX = 177;
   const int sizeY = 198;
   int dataSize = sizeX * sizeY;
   std::vector<double> data(dataSize);
   std::vector<double> dataOrig(dataSize);
   for (int i = 0; i < dataSize; i++) {
      data = rand() % 256;
      dataOrig = data;
   vector<double> my_hist(256);
   for (size_t i = 0; i < my_hist.size(); i++) {
      my_hist[255 - i] = int(1. / (255. * 255. * 255.) * pow(i, 4) + 0.5);
   double outNewFunction = bringHistSpec(&my_hist[0]);
   double outOrigFunction = bringHistSpecOrig(&my_hist[0]);
   printf("new %.12f\n", outNewFunction);
   printf("orig %.12f\n", outOrigFunction);
   return 0;
[/cpp]
icc -O2 -g3 -no-vec -Wall -c -fmessage-length=0 -MMD -MP -MF"src/FR2013Tests.d" -MT"src/FR2013Tests.d" -o"src/FR2013Tests.o" "../src/FR2013Tests.cpp"
icc version 13.1.2 (gcc version 4.6.0 compatibility)  - composer_xe_2013.4.183
OpenSuse 12.1
I ran this program with O1 there is not mistake, with O3 there is mistake.
I ran this program with O2 and without "-no-vec" there is mistake, with O3 and without "-no-vec" there is not mistake.
Can somebody help me?
TimP
You could expect small changes in numerical results when you vectorize with -no-prec-div so as to permit reciprocal-math optimizations, and when you vectorize sum reductions.  The option -fp-model source would imply -prec-div, and prevent vectorized sum reduction.
Komarov__Alexander
Thanks for the answer. I tried to run my program with this options(-prec-div and -fp-model), but i have old problem again.
This is output my program:
new 43789.999999999992724
orig 43790.000000000014552
How I understand my problem is bug of compiler. Am I right? If yes, What should I do next?
QIAOMIN_Q_
can you try the compiler's latest version from the registeration center?
 "with O3 and without "-no-vec" there is not mistake. "looks confusing ,could you provide the full options ?
You mean the add '-fp-model source' is of no help to the outcome's correctness?
Komarov__Alexander
I'm sorry. I wasn't right to use "-fp-model". With options, there is not mistake. I think it's not bug. Thanks for help.
But with O3 and without "-no-vec", without "-fp-model source", there is not mistake.
With O2 and without "-no-vec", without "-fp-model source", there is mistake.
