I optimized my code and after that some operation. I have a mistake of accuracy with original version.
I wrote this example that repeats a mistake of the accuracy. But I don't know this bug or it's normal.
[cpp]
#include <iostream>
#include <stdlib.h>
#include <vector>
#include <stdio.h>
using namespace std;
double bringHistSpec(const double *my_hist) {
const int NLI = 256;
int n = 1000;
double sump_ = 300;
double p[NLI];
for (int i = 0; i < NLI; i++) {
p = my_hist;
p=p * n / sump_;
double sump = 0.0;
sump += p;
return sump;
double bringHistSpecOrig(const double *my_hist) {
int n = 1000;
double sump_ = 300;
double p[NLI];
p = my_hist;
//for (int i = 0; i < NLI; i++) {
// p=p * n / sump_;
double sump = 0.0;
p=p * n / sump_;
sump += p;
return sump;
int main() {
const int sizeX = 177;
const int sizeY = 198;
int dataSize = sizeX * sizeY;
std::vector<double> data(dataSize);
std::vector<double> dataOrig(dataSize);
for (int i = 0; i < dataSize; i++) {
data = rand() % 256;
dataOrig = data;
vector<double> my_hist(256);
for (size_t i = 0; i < my_hist.size(); i++) {
my_hist[255 - i] = int(1. / (255. * 255. * 255.) * pow(i, 4) + 0.5);
double outNewFunction = bringHistSpec(&my_hist[0]);
double outOrigFunction = bringHistSpecOrig(&my_hist[0]);
printf("new %.12f\n", outNewFunction);
printf("orig %.12f\n", outOrigFunction);
return 0;
[/cpp]
icc -O2 -g3 -no-vec -Wall -c -fmessage-length=0 -MMD -MP -MF"src/FR2013Tests.d" -MT"src/FR2013Tests.d" -o"src/FR2013Tests.o" "../src/FR2013Tests.cpp"
icc version 13.1.2 (gcc version 4.6.0 compatibility) - composer_xe_2013.4.183
OpenSuse 12.1
I ran this program with O1 there is not mistake, with O3 there is mistake.
I ran this program with O2 and without "-no-vec" there is mistake, with O3 and without "-no-vec" there is not mistake.
Can somebody help me?
You could expect small changes in numerical results when you vectorize with -no-prec-div so as to permit reciprocal-math optimizations, and when you vectorize sum reductions. The option -fp-model source would imply -prec-div, and prevent vectorized sum reduction.
Thanks for the answer. I tried to run my program with this options(-prec-div and -fp-model), but i have old problem again.
This is output my program:
new 43789.999999999992724
orig 43790.000000000014552
How I understand my problem is bug of compiler. Am I right? If yes, What should I do next?
can you try the compiler's latest version from the registeration center?
"with O3 and without "-no-vec" there is not mistake. "looks confusing ,could you provide the full options ?
You mean the add '-fp-model source' is of no help to the outcome's correctness?
I'm sorry. I wasn't right to use "-fp-model". With options, there is not mistake. I think it's not bug. Thanks for help.
But with O3 and without "-no-vec", without "-fp-model source", there is not mistake.
With O2 and without "-no-vec", without "-fp-model source", there is mistake.
