Intel® C++ Compiler
7931 Discussions
[Bug report] ICC internal error when trying to assign a subword of an __m128 in an array directly
Hugh_D_
The following code provokes a compiler internal error with ICC 16.0.1 on Ubuntu 14.04, while GCC 4.8 compiles it without any problem :
#include <immintrin.h>
int main(void) {
  __m128 v[2];
  v[0][0] = 1.0f;
  return 0;
The error output is:
$ icc test.c
": internal error: ** The compiler has encountered an unexpected problem.
** Segmentation violation signal raised. **
Access violation or stack overflow. Please contact Intel Support for assistance.
compilation aborted for test.c (code 4)
Now replacing the line
  v[0][0] = 1.0f;
by
  v[0] =  _mm_set_ss(1.0f);
ICC compiles the source fine.
Perhaps I should not assign a subword like this, since I rely on the implementation, but I guess that nobody would expect the compiler to crash like this.
Anoop_M_Intel
I agree that the compiler should not crash with a segfault in such case. I have escalated this issue to compiler engineering.
Thanks and Regards
Anoop
jimdempseyatthecove
Black Belt
v[0].m128_f32[0] = 1.0f;
Jim Dempsey
Hugh_D_
Jim Dempsey
Thanks, but this is less portable than using _mm_set_[sp]s.
It will probably not compile with GCC and may not compile with ICC, because the type _m128 has several possible definitions, depending on predefined macros (see Intel's immintrin.h header)
Anoop_M_Intel
This issue is fixed in 17.0 compiler which is available at Intel Registration Center.
Thanks and Regards
Anoop
