Steps to reproduce:
1.) Install VS 2012 on Windows 8.1 Pro 64 Bit.
2.) Install the latest Intel Compilers with VS 2012 integration.
3.) Install the Windows Phone 8 SDK.
4.) Create some simple Windows Phone app.
5.) Set a breakpoint somewhere
6.) Debug the app.
7.) Hit the breakpoint.
Expected results:
You should be able to view expressions and variables.
Actual results:
The "locals" window is empty. When you add any expression to watch you only get error 0x8ede0018.
Workaround:
Uninstall the Intel Compiler integration and the problem is gone. (Unfortunately, the Intel Compiler integration is gone, too.)
>>Actual results:
>>Workaround:
I wonder if the problem is gone when you switch to 'Use Microsoft C++ compiler'? Could you verify it?
