Intel® C++ Compiler
[Bug report] Spurious #2651 warning for deprecating a "using" alias.
Daniel_A_1
Dear all,
trying to deprecate a "using" alias as in
 using foo [[deprecated]] = int;
 int main()
   foo f = 1;
gives me
test-deprecate.cc(1): warning #2651: attribute does not apply to any entity
test-deprecate.cc(5): warning #1478: type "foo" (declared at line 1) was declared deprecated
    foo f = 1;
using ICC16, ICC17, ICC18 and ICC19. The deprecation is correctly detected by warning #1478 so #2651 is spurious here.
Best,
Daniel
Viet_H_Intel
Hi Daniel,
What are  your command line options?
Viet
Daniel_A_1
Hi Viet, I am just using "-std=c++14". I can also reproduce this using godbolt: https://godbolt.org/g/p7Y8Tz Best, Daniel
Viet_H_Intel
Does GNU compiler gives you a warning as well?
Viet
Daniel_A_1
gcc generates the expected deprecation warning from version 4.9.0 on and clang from version 3.3 on.
Best,
Daniel
Viet_H_Intel
You can suppress it by -wd2651.
Viet
Daniel_A_1
Of course, I can suppress it with -wd2651. That was never the question. It should just not have appeared in the first place. This is why I labeled the topic "bug report".
Best,
Daniel
Miltenberger__Matthi
So, has there been any progress or is the suppression still the only viable choice?
