First of all, sorry for this report, it looks like a nasty bug and I can't give you a simple reproducer (closed source and stripped-down example just works fine).
I'm performing the following calls on a highly templated with many inheritance code:
[cpp]size += static_cast<std::vector<pairN>>(_ref.A::_map)
size += _ref.A::_map
The first line compiles fine, the second does not, with the following error message:
error: no operator "[]" matches these operands
operand types are: const vectorN [ unsigned short ]
With [cpp]typedef std::pair<unsigned short, std::vector<int>> pairN; typedef std::vector<pairN> vectorN;[/cpp]
Of course, I don't have any problem with clang++ or g++. Any ideas ? Why on earth should I have to cast _ref.A::_map to its own type ?
Thank you.
Still can't edit the first post it appears ... Here is a reproducer:
[cpp]
#include <vector>
template<class T>
class FooBase {
protected:
const T& _ref;
public:
FooBase(const T& ref) : _ref(ref) { };
class Bar {
protected:
vectorN _map;
template<class Useless>
class B : public Bar {
private:
class Foo;
Foo* _t;
public:
inline void update() {
_t->update();
class B<Useless>::Foo : FooBase<B<Useless>> {
private:
typedef FooBase<B<Useless>> base;
using base::_ref;
public:
Foo(const B<Useless>& f) : base(f) { };
unsigned int size = 0;
for(unsigned short j = 0; j < _ref.Bar::_map.size(); ++j) {
size += _ref.Bar::_map.operator[](j).second.size(); // OK
size += static_cast<const vectorN>(_ref.Bar::_map)
int main() {
B<void>* f = new B<void>();
f->update();
delete f;
return 0;
}[/cpp]
Can you reproduce the error on your side ? Works fine with g++ and clang++ and C++11.
It looks like my original title is quite misleading, but I can't edit that ... Indeed, the problem seems to be related with forward declaration, since the following code compiles fine with icpc too:
[cpp]
#include <vector>
template<class T>
class FooBase {
protected:
const T& _ref;
public:
class Bar {
protected:
vectorN _map;
class B : Bar {
private:
class Foo : FooBase<B> {
private:
typedef FooBase<B> base;
using base::_ref;
public:
Foo(const B& f) : base(f) { };
Foo* _t;
public:
_t->update();
int main() {
B* f = new B();
f->update();
delete f;
return 0;
}[/cpp]
So how to fix my original problem now ? Thanks for your help.
I have been able to reproduce this and have entered it into our internal bug tracking database as DPD200249732. It seems to be a problem with template aliases and references. I see that you have already come up with a couple of workarounds, one other one (which actually makes the code simpler is to remove the unnecessary Bar qualification, i.e.:
#ifdef OK
size += _ref._map
#else
#endif
Thank you for bringing it to our attention.
Judy
Hello Judy, you are 100% right ! Thanks for the (much better) workaround. Sorry for all the trouble.
