Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
Bug
Alex_K_4
Usage of static constexpr member-function or member-variable, declared within a template, causes compiler error, if declared member-function or member-variable is further used within the same template.
Platform: Win 7, x86, Intel Parallel Studio 15 Update 6
Example:
template<typename T, int n> class test_template
public:
static constexpr int double_sz() {
return 2 * n;
T arr[double_sz()];
Here static constexpr member-function double_sz() is further used to define the size of array, declared within the same template. Result: compiler error "function call must have a constant value in a constant expression".
Garipov__Ruslan
I got the same issue in Intel C++ 16 Update 2. It's described in my post @ stackoverflow.
Do we have any chance to get a reply from Intel team's member?
Anoop_M_Intel
I can reproduce the problem which you report. I will escalate this to engineering and keep you posted on their update:
  public:
       return 2 * n;
  T arr[double_sz()];
test_template<int,10> foo;
>icl /c static.cpp /Qstd=c++11
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.6.285 Build 20151119
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
static.cpp
static.cpp(13): error: function call must have a constant value in a constant expression
  T arr[double_sz()];
          detected during instantiation of class "test_template<T, n> [with T=int, n=10]" at line 17
compilation aborted for static.cpp (code 2)
Thanks and Regards
Anoop
Judith_W_Intel
A possible workaround would be to use a constexpr variable instead of a constexpr routine, i.e.:
  static constexpr int double_sz = 2 *n;
  T arr[double_sz];
