I'm using parallel studio 2016 professional and visual studio 2015.
Boost seem not to be able to find my Intel Compiler when I I run bootstrap.bat. I will only adds "MSVC" and not the Intel compiler.
How can I get it to use the Intel compiler?
Did you open up a command window using the Intel compiler installed shortcut and run the bootstrap.bat there?
I don't have an answer to your question per se, but it's ok to bootstrap with the host compiler and run b2 to build the library etc with the Intel compiler.
Following upon this one ( it also applies to boost 1.60).
The problem is the file "intel-win.jam" that does not have support for Intel 16.0 compilers.
.intel-autodetect-versions = 16.0 15.0 14.0 13.0 12.0 ;
.iclvars-12.0-supported-vcs = "10.0 9.0 8.0" ;
.iclvars-12.1-supported-vcs = "10.0 9.0 8.0" ;
.iclvars-13.0-supported-vcs = "11.0 10.0 9.0" ;
.iclvars-14.0-supported-vcs = "12.0 11.0 10.0 9.0" ;
.iclvars-15.0-supported-vcs = "12.0 11.0 10.0 9.0" ;
.iclvars-16.0-supported-vcs = "14.0 12.0 11.0 10.0 9.0" ;
.iclvars-version-alias-vc14 = vs2015 ;
Then you can build with....
b2 --toolset=intel-16.0 --sINTEL_BASE_MSVC_TOOLSET=msvc-14.0
But don't forget to add to boost\config\compiler\intel.hpp (until the 16.0 compiler is updated)
#if (_MSC_VER>1899)
#define __builtin_huge_val() HUGE_VAL
#define __builtin_huge_valf() HUGE_VALF
#define __builtin_nan nan
#define __builtin_nanf nanf
#define __builtin_nans nan
#define __builtin_nansf nanf
#endif
Actually much better than modifying boost\config\compiler\intel.hpp is to build using...
b2 define="__builtin_nan=nan" define="__builtin_huge_val()=HUGE_VAL" define="__builtin_huge_valf()=HUGE_VALF" define="__builtin_nanf=nanf" define="__builtin_nans=nan" define="__builtin_nansf=nanf" --toolset=intel-16.0 --sINTEL_BASE_MSVC_TOOLSET=msvc-14.0
That shouldn't work if IPSXE 2016 installed without Visual Studio. But for some reasons command 'bootstrap intel-win32' (details in files 'BOOST\tools\build\src\engine\build.<bat,jam>') fails to build bjam. Therefore the easiest way to prepare BOOST build system is to use 'bootstrap' or 'bootstrap msvc' commands with Visual Studio preinstalled.
b2 ..... --toolset=intel-16.0 --sINTEL_BASE_MSVC_TOOLSET=msvc-14.0
With BOOST 1.60.0 released parameter 'toolset=intel-16.0-vc14' works fine too.
Alexander
