Hi.
I'm trying to build Python 3.7 on CentOS 7 with Intel compilers. I'm using version 2018 of the compiler.
To compile I do the following:
export CC=icc export CXX=icpc export FC=ifort ./configure --prefix=my_prefix --enable-optimizations --without-gcc make make install
In the configure, no error is seen, but when I execute make, the following message is printed:
Running code to generate profile data (this can take a while): # First, we need to create a clean build with profile generation # enabled. make profile-gen-stamp make[1]: se ingresa al directorio `/home/python/source/Python-3.7.3' Building with support for profile generation: make build_all_generate_profile make[2]: se ingresa al directorio `/home/python/source/Python-3.7.3' make build_all CFLAGS_NODIST=" -prof-gen" LDFLAGS_NODIST=" -prof-gen" LIBS="-lcrypt -lpthread -ldl -lutil" make[3]: se ingresa al directorio `/home/python/source/Python-3.7.3' icc -pthread -c -Wsign-compare -Wunreachable-code -DNDEBUG -g -O3 -Wall -std=c99 -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -Wno-cast-function-type -Werror=implicit-function-declaration -fp-model strict -prof-gen -I. -I./Include -DPy_BUILD_CORE -o Programs/python.o ./Programs/python.c icc: command line warning #10006: ignoring unknown option '-Wno-cast-function-type' In file included from ./Include/Python.h(75), from ./Programs/python.c(3): ./Include/pyatomic.h(39): error: identifier "atomic_uintptr_t" is undefined atomic_uintptr_t _value; ^ compilation aborted for ./Programs/python.c (code 2)
I have searched but I can not find the solution to the error. Any ideas?
Can you try the 2019 update 4 version?
No. I do not know if I can have the version you told me. Still, would a new version fix the error?
I don't know if this will help. But give it a try: https://blog.semicolonsoftware.de/compiling-python-numpy-and-scipy-with-intel-compilers-and-intel-mkl/
btw. using the latest compiler is always a good idea. you can download an eval copy to start with.
Jennifer
I confirm that the problem exists with 2019 update 4...
And following the blog.semicolonsoftware.de link also leads to the same error.
Can you create a preprocessed file for python.c.
I am having the same problem trying to compile python 3.7.4. Is there a solution? For me the make process fails quite early:
icc -pthread -c -Wsign-compare -Wunreachable-code -DNDEBUG -g -O3 -Wall -std=c99 -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -Wno-cast-function-type -Werror=implicit-function-declaration -fp-model strict -prof-gen -I. -I./Include -I/discover/nobackup/projects/tm5var4d/packages/openssl/1.1.0h/include -I/discover/nobackup/projects/tm5var4d/packages/python3_prereqs/include -fPIC -DPy_BUILD_CORE -o Programs/python.o ./Programs/python.c icc: command line warning #10006: ignoring unknown option '-Wno-cast-function-type' In file included from ./Include/Python.h(75), from ./Programs/python.c(3): ./Include/pyatomic.h(39): error: identifier "atomic_uintptr_t" is undefined atomic_uintptr_t _value; ^ compilation aborted for ./Programs/python.c (code 2)
Can you provide us preprocessed file (by replacing -c with -E)? Make sure you are still able to compile the preprocessed file and see the same error by replacing python.c with python.i.
For more complete information about compiler optimizations, see our Optimization Notice.
