Intel® C++ Compiler
Build fails using ICC but not GCC
Jonathan_L_Intel1
Hi all,
I am building ITK from source. I have had the same issue on Centos 7 and Ubuntu 14.04 systems running on Xeon Broadwell systems.
Building with GCC
When I use cmake to configure for a standard build using gcc, it use this method below. The compilation completes and works well.
mkdir build; cd build;
cmake -D Module_PerformanceBenchmarking:BOOL=ON ..
make
Building with ICC (latest release 2017; update 2 16 Feb 2017)
When I use cmake to configure for a standard build using Intel compiler, it use this method below. The compilation completes and works well.
CC=/opt/bin/icc CXX=/opt/bin/icc cmake -DCMAKE_CXX_COMPILER:FILEPATH=/opt/bin/icc -DCMAKE_C_COMPILER:FILEPATH=/opt/bin/icc -DModule_PerformanceBenchmarking:BOOL=ON ..
make
There is this problem with Centos 7
Scanning dependencies of target ITKTransform-all
[ 58%] Built target ITKTransform-all
[ 58%] Building CXX object Modules/Core/ImageFunction/test/CMakeFiles/ITKImageFunctionTestDriver.dir/itkRayCastInterpolateImageFunctionTest.cxx.o
/src/ITK/Modules/Core/ImageFunction/include/itkRayCastInterpolateImageFunction.hxx(38): error: member "<unnamed>::RayCastHelper<TInputImage, TCoordRep>::InputImageDimension [with TInputImage=itk::Image<unsigned char, 3U>, TCoordRep=double]" was referenced but not defined
    itkStaticConstMacro(InputImageDimension, unsigned int,
compilation aborted for /src/ITK/Modules/Core/ImageFunction/test/itkRayCastInterpolateImageFunctionTest.cxx (code 2)
make[2]: *** [Modules/Core/ImageFunction/test/CMakeFiles/ITKImageFunctionTestDriver.dir/itkRayCastInterpolateImageFunctionTest.cxx.o] Error 2
make[1]: *** [Modules/Core/ImageFunction/test/CMakeFiles/ITKImageFunctionTestDriver.dir/all] Error 2
make: *** [all] Error 2
I get this problem when I use Ubuntu 14.04
Building CXX object Modules/Filtering/LabelMap/test/CMakeFiles/ITKLabelMapTestDriver.dir/itkBinaryImageToLabelMapFilterTest2.cxx.o
[ 68%] icc: error #10106: Fatal error in /opt/compilers_and_libraries_2017.2.174/linux/bin/intel64/mcpcom, terminated by kill signal
compilation aborted for /path/ITK/ITK-IntelCompiler/build/Modules/Segmentation/SignedDistanceFunction/test/ITKSignedDistanceFunctionTestDriver.cxx (code 1)
compilation aborted for /path/ITK/ITK-IntelCompiler/build/Modules/IO/BioRad/test/ITKIOBioRadTestDriver.cxx (code 1)
make[2]: *** [Modules/IO/XML/test/CMakeFiles/ITKIOXMLTestDriver.dir/ITKIOXMLTestDriver.cxx.o] Error 1
I need help getting past this issue. Thank you.
Yuan_C_Intel
Hi, Jonathan
Besides reset CC and CXX to icc, have you setup your environment with icc configuration script?
$ source /opt/intel/compilers_and_libraries_2017.2.174/linux/bin/compilervars.sh intel64
This will setup icc bin and library paths.
If your installation is not in default path, please make sure icc include folder is referenced correctly by adding -I or -Qlocation,cxxinc,dir.
You may also try use icc as linker by setting LD=icc
TimP
CXX should be icpc in the usual case where c++ linking is needed.
Jonathan_L_Intel1
Thank you for the suggestion. Even after changing the CXX to icpc, I still receive the same issue on both Ubuntu and Centos systems.
ITK/ITK-IntelCompiler/Modules/Core/ImageFunction/include/itkRayCastInterpolateImageFunction.hxx(38): error: member "<unnamed>::RayCastHelper<TInputImage, TCoordRep>::InputImageDimension [with TInputImage=itk::Image<unsigned char, 3U>, TCoordRep=double]" was referenced but not defined
Jonathan_L_Intel1
Additional information about the cmake configuration for icc/icpc flags from VTK are here
    if (${CMAKE_C_COMPILER} MATCHES "icc.*$")
      set(USING_INTEL_ICC_COMPILER TRUE)
    endif()
    if (${CMAKE_CXX_COMPILER} MATCHES "icpc.*$")
    endif()
    if(USING_INTEL_ICC_COMPILER)
      # NOTE -w2 is close to gcc's -Wall warning level, -w5 is intels -Wall warning level, and it is too verbose.
      set(VerboseWarningsFlag -w2 -wd1268 -wd981 -wd383 -wd1418 -wd1419 -wd2259 -wd1572 -wd424 )
      #-wd424  #Needed for Intel compilers with remarki  #424: extra ";" ignored
      #-wd383  #Needed for Intel compilers with remark   #383: value copied to temporary, reference to temporary used
      #-wd981  #Needed for Intel compilers with remark   #981: operands are evaluated in unspecified order
      #-wd1418 #Needed for Intel compilers with remark  #1418: external function definition with no prior declaration
      #-wd1419 #Needed for Intel compilers with remark  #1419: external declaration in primary source file
      #-wd1572 #Needed for Intel compilers with remark  #1572: floating-point equality and inequality comparisons are unreliable
      #-wd2259 #Needed for Intel compilers with remark  #2259: non-pointer conversion from "itk::SizeValueType={unsigned long}" to "double" may lose significant bits
      #-wd1268 #Needed for Intel compliers with warning #1268: support for exported templates is disabled
    else()
      set(VerboseWarningsFlag -Wall )
    endif ()
  endif()
Judith_W_Intel
I can reproduce the diagnostic with this example:
namespace {
   template <class T>
   struct RayCastHelper {
     void foo(); // since this is inside unnamed namespace, it needs to be defined in the translation unit
void f() {
   RayCastHelper<int> r;
   r.foo();
But I only see a warning not an error. Anything that is declared inside an unnamed namespace should be defined in that translation unit because there is  no possibility of a definition elsewhere. I don't understand why you are seeing an error and not a warning. If you could create a preprocessed file and attach it (add the -E or -P option to the compilation) then we could give you more help.
thanks
Judy
Judith_W_Intel
Thanks for the reproducer.
I have recorded this bug as DPD200419770 in out internal bugs database.
Details on the problem are:
Here’s a small example below that compiles with GNU but not Intel. This looks like the problem is with a static data member called InputImageDimension declared inside class RayCastHelper.
The member is used inside a member function called Initialise.
This is an Intel compiler bug – while technically there is no static member definition (what’s inside the class is only a declaration) I don’t think the compiler should be complaining. Especially if GNU allows it.
In the meantime I see two possible workarounds:
  1. The “use” in this case is not needed, i.e. the statement  “ (void)InputImageDimension;”  doesn’t do anything. So you can remove it or comment it out. See attached diff1.txt for that solution. You would need that change on about line 302 of  /mnt/intel/ccc/tmp/ITK/ITK-IntelCompiler/Modules/Core/ImageFunction/include/itkRayCastInterpolateImageFunction.hxx.
  2. Add a static member definition. See attached diff2.txt for an example. You will need to move the initializer from the declaration to the definition.  The definition should go after the class declaration.
// this compiles with g++ but not icpc
namespace {
template< typename T>
static const unsigned int InputImageDimension = 0;
  void Initialise();
void RayCastHelper< T>::Initialise(void)
int main() {
  r.Initialise();
  return 0;
