Hi all,
I am building ITK from source. I have had the same issue on Centos 7 and Ubuntu 14.04 systems running on Xeon Broadwell systems.
Building with GCC
When I use cmake to configure for a standard build using gcc, it use this method below. The compilation completes and works well.
mkdir build; cd build; cmake -D Module_PerformanceBenchmarking:BOOL=ON .. make
Building with ICC (latest release 2017; update 2 16 Feb 2017)
When I use cmake to configure for a standard build using Intel compiler, it use this method below. The compilation completes and works well.
mkdir build; cd build; CC=/opt/bin/icc CXX=/opt/bin/icc cmake -DCMAKE_CXX_COMPILER:FILEPATH=/opt/bin/icc -DCMAKE_C_COMPILER:FILEPATH=/opt/bin/icc -DModule_PerformanceBenchmarking:BOOL=ON .. cmake -D Module_PerformanceBenchmarking:BOOL=ON .. make
There is this problem with Centos 7
Scanning dependencies of target ITKTransform-all [ 58%] Built target ITKTransform-all [ 58%] Building CXX object Modules/Core/ImageFunction/test/CMakeFiles/ITKImageFunctionTestDriver.dir/itkRayCastInterpolateImageFunctionTest.cxx.o /src/ITK/Modules/Core/ImageFunction/include/itkRayCastInterpolateImageFunction.hxx(38): error: member "<unnamed>::RayCastHelper<TInputImage, TCoordRep>::InputImageDimension [with TInputImage=itk::Image<unsigned char, 3U>, TCoordRep=double]" was referenced but not defined itkStaticConstMacro(InputImageDimension, unsigned int, ^ compilation aborted for /src/ITK/Modules/Core/ImageFunction/test/itkRayCastInterpolateImageFunctionTest.cxx (code 2) make[2]: *** [Modules/Core/ImageFunction/test/CMakeFiles/ITKImageFunctionTestDriver.dir/itkRayCastInterpolateImageFunctionTest.cxx.o] Error 2 make[1]: *** [Modules/Core/ImageFunction/test/CMakeFiles/ITKImageFunctionTestDriver.dir/all] Error 2 make: *** [all] Error 2
I get this problem when I use Ubuntu 14.04
Building CXX object Modules/Filtering/LabelMap/test/CMakeFiles/ITKLabelMapTestDriver.dir/itkBinaryImageToLabelMapFilterTest2.cxx.o [ 68%] icc: error #10106: Fatal error in /opt/compilers_and_libraries_2017.2.174/linux/bin/intel64/mcpcom, terminated by kill signal compilation aborted for /path/ITK/ITK-IntelCompiler/build/Modules/Segmentation/SignedDistanceFunction/test/ITKSignedDistanceFunctionTestDriver.cxx (code 1) icc: error #10106: Fatal error in /opt/compilers_and_libraries_2017.2.174/linux/bin/intel64/mcpcom, terminated by kill signal compilation aborted for /path/ITK/ITK-IntelCompiler/build/Modules/IO/BioRad/test/ITKIOBioRadTestDriver.cxx (code 1) make[2]: *** [Modules/IO/XML/test/CMakeFiles/ITKIOXMLTestDriver.dir/ITKIOXMLTestDriver.cxx.o] Error 1
I need help getting past this issue. Thank you.
Hi, Jonathan
Besides reset CC and CXX to icc, have you setup your environment with icc configuration script?
$ source /opt/intel/compilers_and_libraries_2017.2.174/linux/bin/compilervars.sh intel64
This will setup icc bin and library paths.
If your installation is not in default path, please make sure icc include folder is referenced correctly by adding -I or -Qlocation,cxxinc,dir.
You may also try use icc as linker by setting LD=icc
CXX should be icpc in the usual case where c++ linking is needed.
Thank you for the suggestion. Even after changing the CXX to icpc, I still receive the same issue on both Ubuntu and Centos systems.
ITK/ITK-IntelCompiler/Modules/Core/ImageFunction/include/itkRayCastInterpolateImageFunction.hxx(38): error: member "<unnamed>::RayCastHelper<TInputImage, TCoordRep>::InputImageDimension [with TInputImage=itk::Image<unsigned char, 3U>, TCoordRep=double]" was referenced but not defined itkStaticConstMacro(InputImageDimension, unsigned int, ^
Additional information about the cmake configuration for icc/icpc flags from VTK are here
if (${CMAKE_C_COMPILER} MATCHES "icc.*$") set(USING_INTEL_ICC_COMPILER TRUE) endif() if (${CMAKE_CXX_COMPILER} MATCHES "icpc.*$") set(USING_INTEL_ICC_COMPILER TRUE) endif() if(USING_INTEL_ICC_COMPILER) # NOTE -w2 is close to gcc's -Wall warning level, -w5 is intels -Wall warning level, and it is too verbose. set(VerboseWarningsFlag -w2 -wd1268 -wd981 -wd383 -wd1418 -wd1419 -wd2259 -wd1572 -wd424 ) #-wd424 #Needed for Intel compilers with remarki #424: extra ";" ignored #-wd383 #Needed for Intel compilers with remark #383: value copied to temporary, reference to temporary used #-wd981 #Needed for Intel compilers with remark #981: operands are evaluated in unspecified order #-wd1418 #Needed for Intel compilers with remark #1418: external function definition with no prior declaration #-wd1419 #Needed for Intel compilers with remark #1419: external declaration in primary source file #-wd1572 #Needed for Intel compilers with remark #1572: floating-point equality and inequality comparisons are unreliable #-wd2259 #Needed for Intel compilers with remark #2259: non-pointer conversion from "itk::SizeValueType={unsigned long}" to "double" may lose significant bits #-wd1268 #Needed for Intel compliers with warning #1268: support for exported templates is disabled else() set(VerboseWarningsFlag -Wall ) endif () endif()
I can reproduce the diagnostic with this example:
namespace {
template <class T>
struct RayCastHelper {
void foo(); // since this is inside unnamed namespace, it needs to be defined in the translation unit
void f() {
RayCastHelper<int> r;
r.foo();
But I only see a warning not an error. Anything that is declared inside an unnamed namespace should be defined in that translation unit because there is no possibility of a definition elsewhere. I don't understand why you are seeing an error and not a warning. If you could create a preprocessed file and attach it (add the -E or -P option to the compilation) then we could give you more help.
thanks
Judy
Thanks for the reproducer.
I have recorded this bug as DPD200419770 in out internal bugs database.
Details on the problem are:
Here’s a small example below that compiles with GNU but not Intel. This looks like the problem is with a static data member called InputImageDimension declared inside class RayCastHelper.
The member is used inside a member function called Initialise.
This is an Intel compiler bug – while technically there is no static member definition (what’s inside the class is only a declaration) I don’t think the compiler should be complaining. Especially if GNU allows it.
In the meantime I see two possible workarounds:
The “use” in this case is not needed, i.e. the statement “ (void)InputImageDimension;” doesn’t do anything. So you can remove it or comment it out. See attached diff1.txt for that solution. You would need that change on about line 302 of /mnt/intel/ccc/tmp/ITK/ITK-IntelCompiler/Modules/Core/ImageFunction/include/itkRayCastInterpolateImageFunction.hxx.
Add a static member definition. See attached diff2.txt for an example. You will need to move the initializer from the declaration to the definition. The definition should go after the class declaration.
// this compiles with g++ but not icpc
namespace {
template< typename T>
static const unsigned int InputImageDimension = 0;
void Initialise();
void RayCastHelper< T>::Initialise(void)
int main() {
r.Initialise();
return 0;
