Intel® C++ Compiler
7956 Discussions
Building a Linux LiveCD with the ICC compiler
TyMac
I would like to build a LiveCD using ICC to build the Kernel along with optimizing certain packages and libs. If I buy the professional version will I be able to use it to distrubte a LiveCD based on its libs and compiler?
I asked the sales group at Intel and they told me to ask this question here.
TimP
Quoting - thaidog
I don't think it makes sense that you couldn't get the question answered. To clarify, I believe you are asking to distribute applications you have built yourself, with static linking of all Intel libraries, no distribution of the actual Intel compiler or libraries. You should read the license yourself, but if you work within those limits, it may be OK.
TyMac
Quoting - tim18
No distobution of the actual compiler, but I think the libs must be on the disk since it will be a livecd.
I guess the question was too technical for them. I have not bought the compiler yet pending this clairification.
Om_S_Intel
The "Redistributables" are the files listed in the following text files that may be included in the Materials for the applicable Intel Software Development Product: clredist.txt, credist.txt, fredist.txt, redist.txt. You should be able to distribute the libraries and other files that your application is dependent. You may download the evaluation version of compiler and review the above file.
I think, this istoo technical for sales team and they not be able to tell what files you can redistribute.
Om_S_Intel
Thelink http://software.intel.com/en-us/articles/distributing-library-files/ contains list of redistribution files from Intel C++ compiler 11.0 professional edition. Yoy may need appropriate license to redistribute the files.
TyMac
Awsome! I have passed this along to LuYi who is actualy building the system right now with a free license (he will not redistrube this test build of course!)
