i try to build newest boost libraries, version 1.73 with Intel C++ 19.1 update 1 and Visual C++ 16.5.5 (also with 16.5.4). For example filesystem library.
Command line:
.\b2 architecture=x86 address-model=32 stage --build-type=complete --stagedir=address-model-32 --toolset=intel-19.1-vc14.2 --with-filesystem > ..\icpp32.txt
With latest standard:
.\b2 cxxstd=latest architecture=x86 address-model=32 stage --build-type=complete --stagedir=address-model-32 --toolset=intel-19.1-vc14.2 --with-filesystem > ..\icpp32latest.txt
It fails with many errors such as:
C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\VC\Tools\MSVC\14.25.28610\include\utility(96): error: expected an identifier
!_Is_implicitly_default_constructible<_Uty1>::value || !_Is_implicitly_default_constructible<_Uty2>::value)
C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\VC\Tools\MSVC\14.25.28610\include\utility(95): error: not a valid member class or function template declaration
constexpr explicit(
Any clue how to get this work?
Greetings
Przemek
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Try running this command from Path_to_boost\boost_1_73_0 directory to build specific Boost library(filesystem in this case).
b2 --build-dir=build --with-filesystem toolset=intel-19.1-vc14.2 --build-type=complete stage
Please make sure to source compilervars.bat from <compiler root> path, to enable Intel compilers before executing the above command.
Let us know, in case you face any issues.
--Rahul
it does not work either.
Repro
Starting:
"Compiler 19.1 Update 1 for IA-32 Visual Studio 2019 environment" from "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2020\Compiler and Performance Libraries\Command Prompt with Intel Compiler 19.1 Update 1"
Changing directory to boost root and type:
b2 --build-dir=build --with-filesystem toolset=intel-19.1-vc14.2 --build-type=complete stage > ..\log1.txt
See log file:
constexpr explicit(
C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\VC\Tools\MSVC\14.25.28610\include\utility(95): error: "explicit" is not allowed
constexpr explicit(
C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\VC\Tools\MSVC\14.25.28610\include\utility(97): error: expected a ";"
pair() noexcept(
and so on.
Please follow the below steps and let us know:
#Work on a new copy of boost-1.73.0(either extract the earlier downloaded copy to a new directory or download a fresh copy and extract it) #Source Intel compilers cd C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.0.166\windows\bin (cross check compilers_and_libraries version, it could be different on your machine) compilervars.bat intel64 vs2019 (to source compiler) cd path_to_boost\boost_1_73_0 (Fresh copy of extracted boost library) mkdir build cd tools\build bootstrap.bat (run this bat file to generate b2 build) cd ..\.. tools\build\b2 --build-dir=build --with-filesystem toolset=intel-19.1-vc14.2 --build-type=complete stage
After following these steps, you should be able to see an output similar to this at the end:
build\boost\bin.v2\libs\filesystem\build\intel-vc14.2-win-19.1\release\address-model-64\threading-multi\boost_filesystem -iw-mt-x64-1_73.dll 1 file(s) copied. common.copy C:\Users\rvaidyax\Downloads\New folder\boost_1_73_0\boost_1_73_0\stage\lib\cmake\boost_filesystem-1.73.0\lib boost_filesystem-variant-iw-mt-x64-1_73-shared.cmake build\boost\bin.v2\libs\filesystem\build\intel-vc14.2-win-19.1\release\address-model-64\threading-multi\libboost_filesystem-variant-iw-mt-x64-1_73-shared.cmake 1 file(s) copied. ...updated 234 targets...
Let us know if you face any issues.
--Rahul
Let us know if the solution provided worked.
We are closing this thread, assuming that the solution provided has helped. Feel free to raise a new thread if the issue persists.
