Intel® C++ Compiler
C++0x and windows dll
vetroxl
Hi, has anyone comeacrossany problems using the C++0x features in a dll. I getweirderrorslike "Offset is not a member of _OVERLAPPED"?`
Brandon_H_Intel
Hi vetroxl,
What version of Visual Studio* are you using, and what C++0x features in particular are you using? I took an example from MSDN that uses Overlapped I/O, but I don't get any compiler errors with C++0x enabled on Visual Studio 2008.
vetroxl
Hi I;m using Visual Studio 2008. I'm trying to use the lambda expressions. However, I just have to turn on the C++0x support and I get the errors. I'm also compiling an app using the WTL
vetroxl
[cpp]typedef struct _OVERLAPPED {
    ULONG_PTR Internal;
    ULONG_PTR InternalHigh;
    union {
        struct {
            DWORD Offset;
            DWORD OffsetHigh;
        } DUMMYSTRUCTNAME;
        PVOID Pointer;
    } DUMMYUNIONNAME;
    HANDLE  hEvent;
} OVERLAPPED, *LPOVERLAPPED;
[/cpp]
It looks like it's a problem with anonymous struct in OVERLAPPED definition
Brandon_H_Intel
That looks like what I'm using except that it's missing the DUMMYSTRUCTNAME and DUMMYUNIONNAME names. Did you insert those yourself?
Here is my code (I got this from http://msdn.microsoft.com/en-us/library/aa365603%28v=VS.85%29.aspx and then tweaked it to remove the tmain part so I could compile as a dll) which compiles without error.
[cpp]#include
#include
#include
#include
#define CONNECTING_STATE 0
#define READING_STATE 1
#define WRITING_STATE 2
#define INSTANCES 4
#define PIPE_TIMEOUT 5000
#define BUFSIZE 4096
typedef struct
OVERLAPPED oOverlap;
HANDLE hPipeInst;
TCHAR chRequest[BUFSIZE];
DWORD cbRead;
TCHAR chReply[BUFSIZE];
DWORD cbToWrite;
DWORD dwState;
BOOL fPendingIO;
} PIPEINST, *LPPIPEINST;
VOID DisconnectAndReconnect(DWORD);
BOOL ConnectToNewClient(HANDLE, LPOVERLAPPED);
VOID GetAnswerToRequest(LPPIPEINST);
PIPEINST Pipe[INSTANCES];
HANDLE hEvents[INSTANCES];
__declspec(dllexport) int foo()//int _tmain(VOID)
DWORD i, dwWait, cbRet, dwErr;
BOOL fSuccess;
LPTSTR lpszPipename = TEXT("\\.\pipe\mynamedpipe");
// The initial loop creates several instances of a named pipe
// along with an event object for each instance. An
// overlapped ConnectNamedPipe operation is started for
// each instance.
for (i = 0; i < INSTANCES; i++)
// Create an event object for this instance.
hEvents = CreateEvent(
NULL, // default security attribute
TRUE, // manual-reset event
TRUE, // initial state = signaled
NULL); // unnamed event object
if (hEvents == NULL)
printf("CreateEvent failed with %d.n", GetLastError());
return 0;
Pipe.oOverlap.hEvent = hEvents;
Pipe.hPipeInst = CreateNamedPipe(
lpszPipename, // pipe name
PIPE_ACCESS_DUPLEX | // read/write access
FILE_FLAG_OVERLAPPED, // overlapped mode
PIPE_TYPE_MESSAGE | // message-type pipe
PIPE_READMODE_MESSAGE | // message-read mode
PIPE_WAIT, // blocking mode
INSTANCES, // number of instances
BUFSIZE*sizeof(TCHAR), // output buffer size
BUFSIZE*sizeof(TCHAR), // input buffer size
PIPE_TIMEOUT, // client time-out
NULL); // default security attributes
if (Pipe.hPipeInst == INVALID_HANDLE_VALUE)
printf("CreateNamedPipe failed with %d.n", GetLastError());
return 0;
// Call the subroutine to connect to the new client
Pipe.fPendingIO = ConnectToNewClient(
Pipe.hPipeInst,
&Pipe.oOverlap);
Pipe.dwState = Pipe.fPendingIO ?
CONNECTING_STATE : // still connecting
READING_STATE; // ready to read
while (1)
// Wait for the event object to be signaled, indicating
// completion of an overlapped read, write, or
// connect operation.
dwWait = WaitForMultipleObjects(
INSTANCES, // number of event objects
hEvents, // array of event objects
FALSE, // does not wait for all
INFINITE); // waits indefinitely
// dwWait shows which pipe completed the operation.
i = dwWait - WAIT_OBJECT_0; // determines which pipe
if (i < 0 || i > (INSTANCES - 1))
printf("Index out of range.n");
return 0;
// Get the result if the operation was pending.
if (Pipe.fPendingIO)
fSuccess = GetOverlappedResult(
Pipe.hPipeInst, // handle to pipe
&Pipe.oOverlap, // OVERLAPPED structure
&cbRet, // bytes transferred
FALSE); // do not wait
switch (Pipe.dwState)
// Pending connect operation
case CONNECTING_STATE:
if (! fSuccess)
printf("Error %d.n", GetLastError());
return 0;
Pipe.dwState = READING_STATE;
break;
// Pending read operation
case READING_STATE:
if (! fSuccess || cbRet == 0)
DisconnectAndReconnect(i);
continue;
Pipe.cbRead = cbRet;
Pipe.dwState = WRITING_STATE;
break;
// Pending write operation
case WRITING_STATE:
if (! fSuccess || cbRet != Pipe.cbToWrite)
continue;
break;
default:
printf("Invalid pipe state.n");
return 0;
// The pipe state determines which operation to do next.
// READING_STATE:
// The pipe instance is connected to the client
// and is ready to read a request from the client.
case READING_STATE:
fSuccess = ReadFile(
Pipe.hPipeInst,
Pipe.chRequest,
&Pipe.cbRead,
&Pipe.oOverlap);
// The read operation completed successfully.
if (fSuccess && Pipe.cbRead != 0)
Pipe.fPendingIO = FALSE;
continue;
// The read operation is still pending.
dwErr = GetLastError();
if (! fSuccess && (dwErr == ERROR_IO_PENDING))
Pipe.fPendingIO = TRUE;
continue;
// An error occurred; disconnect from the client.
break;
// WRITING_STATE:
// The request was successfully read from the client.
// Get the reply data and write it to the client.
case WRITING_STATE:
GetAnswerToRequest(&Pipe);
fSuccess = WriteFile(
Pipe.hPipeInst,
Pipe.chReply,
Pipe.cbToWrite,
&cbRet,
&Pipe.oOverlap);
// The write operation completed successfully.
if (fSuccess && cbRet == Pipe.cbToWrite)
continue;
// The write operation is still pending.
continue;
break;
default:
return 0;
return 0;
// DisconnectAndReconnect(DWORD)
// This function is called when an error occurs or when the client
// closes its handle to the pipe. Disconnect from this client, then
// call ConnectNamedPipe to wait for another client to connect.
VOID DisconnectAndReconnect(DWORD i)
// Disconnect the pipe instance.
if (! DisconnectNamedPipe(Pipe.hPipeInst) )
printf("DisconnectNamedPipe failed with %d.n", GetLastError());
// Call a subroutine to connect to the new client.
Pipe.hPipeInst,
&Pipe.oOverlap);
// ConnectToNewClient(HANDLE, LPOVERLAPPED)
// This function is called to start an overlapped connect operation.
// It returns TRUE if an operation is pending or FALSE if the
// connection has been completed.
BOOL ConnectToNewClient(HANDLE hPipe, LPOVERLAPPED lpo)
BOOL fConnected, fPendingIO = FALSE;
// Start an overlapped connection for this pipe instance.
fConnected = ConnectNamedPipe(hPipe, lpo);
// Overlapped ConnectNamedPipe should return zero.
if (fConnected)
printf("ConnectNamedPipe failed with %d.n", GetLastError());
return 0;
switch (GetLastError())
// The overlapped connection in progress.
case ERROR_IO_PENDING:
fPendingIO = TRUE;
break;
// Client is already connected, so signal an event.
case ERROR_PIPE_CONNECTED:
if (SetEvent(lpo->hEvent))
break;
// If an error occurs during the connect operation...
default:
return 0;
return fPendingIO;
VOID GetAnswerToRequest(LPPIPEINST pipe)
_tprintf( TEXT("[%d] %sn"), pipe->hPipeInst, pipe->chRequest);
StringCchCopy( pipe->chReply, BUFSIZE, TEXT("Default answer from server") );
pipe->cbToWrite = (lstrlen(pipe->chReply)+1)*sizeof(TCHAR);
}[/cpp]
And my compiler options:
[plain]1>Intel C++ Compiler Professional for applications running on IA-32, Version 11.1    Build 20100203 Package ID: w_cproc_p_11.1.060
1>Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
1>icl /c /Od -D WIN32 -D _DEBUG -D _WINDOWS -D _USRDLL -D TEST_EXPORTS -D _WINDLL -D _UNICODE -D UNICODE /EHsc /RTC1 /MDd /GS /fp:fast /FoDebug/ /W3 /ZI /Qstd=c++0x /Qvc9 "/Qlocation,link,C:Program Files (x86)Microsoft Visual Studio 9.0VCbin" .testdll.cpp[/plain]
vetroxl
Hi, I'm using the windows 7 sdk... i will try reverting back to the original
vetroxl
hi, went to sdk 6 with directx august 2009... it works now. i did not add those DUMMYXX myself... the file had a comment // for compilers that do not support nameless structs/unions
