Should making a derived class "final" cause calls to its virtual member functions to be replaced with static function calls? (Assuming the pointer type of your instance is the final type.) I tested the attached code with gcc & icc, it looks like icc14.0.1 doesn't make this optimization.
Repro :
icc14 final.cpp -std=c++11 -o final.S.icc14 -S -O3 && icc14 final.cpp -std=c++11 -o final.S.icc14F -S -O3 -DFINAL=final
gcc47 final.cpp -std=c++11 -o final.S.gcc47 -S -O3 && gcc47 final.cpp -std=c++11 -o final.S.gcc47F -S -O3 -DFINAL=final
diff final.S.icc14 final.S.icc14F
diff final.S.gcc47 final.S.gcc47F
Output :
$ diff final.S.icc14 final.S.icc14F
3c3
< # mark_description "-std=c++11 -o final.S.icc14 -S -O3";
> # mark_description "-std=c++11 -o final.S.icc14F -S -O3 -DFINAL=final";
$ diff final.S.gcc47 final.S.gcc47F
94d93
< xorl %edi, %edi
97c96
< movb $8, %dil
> movl $8, %edi
99d97
< movq %rax, %rdi
102,103d99
< movq (%rdi), %rax
< call *16(%rax)
Hi intel,
Please can you implement this optimization for the next version of icc. It is potentially useful optimization when you are calling virtual member functions of a template class argument. GCC has already implemented this optimization, so I would expect GCC's C++11 performance to beat ICC in this case.
Thanks ,but your final.cpp is 0 bytes .Can you please check this file ?
Regards.
Attached final.cpp, and pasted below :
#include <stdlib.h>
using namespace std;
class Base {
public :
virtual ~Base() {}
virtual int foo() { return 1; }
};#ifndef FINAL
#define FINAL
#endif
//#define FINAL finalclass Derived FINAL : Base {
public :
virtual ~Derived() {}
virtual int foo() { return 2; }
};int main(int ac, const char **av) {
Derived * d = (rand()==9999) ? NULL : new Derived();
int x = d->foo();
return 0;
