Intel® C++ Compiler
7873 Discussions
C++11 support issue - memory_order_release is undefined
psing51
Dear Sir,
I am trying to compile a code , and i am getting an error:-
icc -c -O2 -lpthread -xHOST -D_XOPEN_SOURCE=500 -D_POSIX_C_SOURCE=200112 -std=c11 -fno-strict-aliasing load.c
load.c(277): warning #266: function "atomic_thread_fence" declared implicitly
                      { atomic_thread_fence(memory_order_release);};
load.c(277): error: identifier "memory_order_release" is undefined
compilation aborted for load.c (code 2)
Is the following version of intel missing c++11 support (http://en.cppreference.com/w/cpp/atomic/memory_order) or am i using wrong flags?
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.3.187 Build 20150407
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
File is attached herewith.
Eagerly awaiting your reply.
Judith_W_Intel
The attached file cannot be compiled because of a missing header file
sptel15-71> icc -c -O2 -lpthread -xHOST -D_XOPEN_SOURCE=500 -D_POSIX_C_SOURCE=200112 -std=c11 -fno-strict-aliasing load.c
load.c(38): catastrophic error: cannot open source file "stdinc.h"
  #include "stdinc.h"
compilation aborted for load.c (code 4)
sptel15-72>
psing51
Here is the application which i am trying to compile: https://github.com/SakalisC/Splash-3/archive/v3.0.tar.gz
I tried compiled the file with various compilers , here are my observations:
[puneet@login02 barnes]$ module purge
[puneet@login02 barnes]$ gcc -c -O2 -lpthread  -D_XOPEN_SOURCE=500 -D_POSIX_C_SOURCE=200112 -std=c11 -fno-strict-aliasing load.c
cc1: error: unrecognized command line option "-std=c11"
[puneet@login02 barnes]$ module load gcc/4.9.3/compilervars
[puneet@login02 barnes]$ module load intel/parallelStudio
[puneet@login02 barnes]$ icc -c -O2 -lpthread  -D_XOPEN_SOURCE=500 -D_POSIX_C_SOURCE=200112 -std=c11 -fno-strict-aliasing load.c
It seems that this version of icc does not support C11. Please confirm if my observations are true so that we could purchase licenses for a newer version of intel suite(which supports the same).
Melanie_B_Intel
Intel support for c11 atomic including the builtin atomic_thread_fence is expected to be available in the 18.0 Linux compiler which will be released later this year.Intel support for c11 atomic including the builtin atomic_thread_fence is expected to be available in the 18.0 Linux compiler which will be released later this year.
As a workaround you could try one of the Intel memory fence intrinsics, here is a forum thread which discusses them. https://software.intel.com/en-us/forums/intel-c-compiler/topic/393396
