Intel® C++ Compiler
7839 Discussions
C++ 13.0 doesn't instantiate the template function
Dmitrichenko__Max
The program below fails to link when buillding it with ICPC version 13.0 under Linux (Intel 64). Using boost version 1.51 (without any patches).
The diagnostics:
/mnt/work/Bender2/Bender2/Sources/TestMod/TestSO.cpp:14: undefined reference to `boost::asio::ip::operator!=(boost::asio::ip::basic_resolver_iterator<boost::asio::ip::tcp> const&, boost::asio::ip::basic_resolver_iterator<boost::asio::ip::tcp> const&)'
/mnt/work/Bender2/Bender2/Sources/TestMod/TestSO.cpp:15: undefined reference to `boost::asio::ip::operator!=(boost::asio::ip::basic_resolver_iterator<boost::asio::ip::tcp> const&, boost::asio::ip::basic_resolver_iterator<boost::asio::ip::tcp> const&)'
This operator is not instantiated. The interesting thing: making connect() method a separate function or removing default value from prototype makes program to link successfuly
[cpp]
#include <boost/asio/ip/tcp.hpp>
class test
void connect(boost::asio::ip::tcp::resolver::iterator et = boost::asio::ip::tcp::resolver::iterator());
using namespace boost::asio::ip;
void test::connect(tcp::resolver::iterator et)
tcp::resolver::iterator end;
if(et != end) {
for(; et != end; ++et) {
break;
int main()
[/cpp]
Dmitrichenko__Max
Is any feedback going to be here from Intel about this bug?
JenniferJ
what the options used? I tested with your code, it did not complain: icl /c /O2 /D_WIN32_WINDOWS /EHsc /I..\boost_1_51_0 boost_err.cpp Jennifer
Dmitrichenko__Max
As I said above "ICPC version 13.0 under Linux (Intel 64)". Why are you trying it under WIN32? Options are following: icpc -std=c++0x -Wall -g -O2 -msse2 -fPIC ....
JenniferJ
Well, the issue is reported now. When working on multiple issues, sometimes the OS does get mixed up. Jennifer
JenniferJ
This issue has been fixed in the 13.0 update2 and later. You can download the latest Intel C++ Composer XE 2013 for Linux from the Intel Registration Center or the eval site.
Jennifer
